Home > Technical > Not tracking straight |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
My 90 had similar symptoms. Came on slowly and there was no obvious event which may have damaged tracking.
Turned out to be siezed track rod and panhard rod bushes were the cause. Replaced, retracked and problem solved. |
29th Oct 2021 12:10pm |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 189 |
Superpro makes some bushes to correct a pull to one side by pushing the front axle a bit forward on that side. They have 2 options, either to correct by 0.5 degree (reference is SPF2717K) or 1 degree (reference is SPF2718K).
I am contemplating going that route at the moment as I do have a slight veer to the right which is rather annoying on long motorway driving. I am in France (LHD). And all tracking is within specs. Having done some intensive research (well, in fact, just a quick googlin') it would seem that RHD Defenders have tendencies to pull left, while LHD ones have tendencies to pull right. The camber of the road might have a role in some cases, obviously, but mine slightly veers to the right on a dead flat surface for sure. I have been wondering as well if using an adjustable panhard rod and playing on the the length can also be a solution ? not sure. /Mat |
2nd Nov 2021 4:43pm |
