- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
claydiggermud
Window winder not working | |
Hi all
My window motor on the drivers side has stopped, so I have checked all the fuses and there is power to the motor, so I think it must be the culprit. Any suggestions TIA.
31st Oct 2021 10:45am |
dorsetsmith
Power to the motor, is this power at motor plug
common problem cable snapping in the rubber garter between ( a ) piler and the door
31st Oct 2021 12:25pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
