Home > Puma (Tdci) > Driving dirt roads with the centre diff locked
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
About 12 years ago I bought my puma and went on the land rover experience 4x4 course. The guy said whenever you go on dirt lock the centre diff. Is this advised? And is there a speed limit to take note off when it's locked.
I did this the other day and it seemed to make the road corrugations seem a bit less bumpy. Could this be?
Post #927893 31st Oct 2021 4:56am
Dinnu
There is no speed limit while using the center diff.
On dirt road, the traction is limited, so there will be no harm using the diff lock. But if it is needed or not, it really depends on the condition of the dirt road.
What is for sure is that the center diff does not like wheel spin. This is because the center diff is working at 3.54 times the speed of the wheels, so a bit of wheel spin means that there is a lot of spinning in the center diff, and will wear it down and destroy it very fast. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #927894 31st Oct 2021 5:59am
Bluest
I do always lock the centre as soon as leaving the tarmac. My belief is that as well as increasing traction and protecting the diff, it stabilises the car, although you do have to be mindful of the potential for under steer, especiallly at speed. 2007 110 TDCi Station Wagon XS
Post #927904 31st Oct 2021 7:54am
Naks
Re: Driving dirt roads with the centre diff locked
Marius wrote:
About 12 years ago I bought my puma and went on the land rover experience 4x4 course. The guy said whenever you go on dirt lock the centre diff. Is this advised? And is there a speed limit to take note off when it's locked. I did this the other day and it seemed to make the road corrugations seem a bit less bumpy. Could this be?
Yes, you should always lock the CDL when going off tar.
I've driven in CDL in Namibia for 4 weeks, no issues. Generally speaking, you shouldn't exceed 80kmh on gravel road anyway, so no issues with the CDL at those speeds. --
Post #927912 31st Oct 2021 9:31am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Well I never would have expected to use difflock on a gravel road as I would not expect a great deal of loss of traction. I only would have expected to use it if I considered I may experience a situation where I was likely to get stuck, so certainly not anything at speed. I would be more inclined to engage it a few times on a gravel road so it gets some use rather than seising up through lack of use!
I think that shows my lack of off road experience, so it's good to see this sort of information. I think a Tom Shepard book may be on my Christmas list!
Post #927925 31st Oct 2021 10:17am
Naks
The rule is simple: as soon as you step off tarred roads, engage the CDL.
On a 90, especially, the CDL makes it a lot more stable on gravel roads. Thumbs Up --
Post #927927 31st Oct 2021 10:32am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I'm not so sure about that simple rule. Just because there's no tar doesn't mean there's little (enough) traction. Also, if you have TC/DSC you can do quite a lot without diff lock. Once I drove up a steep soft-sandy hill without diff lock because I forgot to engage it - no problem at all, TC kicked in.
Post #927951 31st Oct 2021 2:04pm
camelman
I regularly drove 4000km a week for 2 years on Namibian dirt roads without the diff lock.....
Post #927955 31st Oct 2021 2:39pm
jst
if there is a chance of loosing traction you should engage CDL.
CDL is preventative not reactive.
possible loss of traction could be a gravel road it could be a very high traction surface but with vehicle weight not evening distributed.
There is no engineering reason why CDL cant be used at speeds LRs can do. (despite what the sticker says, its more of a wng that you shouldn't be going fast with CDL engaged rather than an eng reason) Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #928140 1st Nov 2021 9:11pm
When the LT230 was introduced the advice from LR was that you should engage the CDL whenever in the old days you'd press the yellow knob. That was at a time when LR still understood off-road vehicles and engineering and was sound advice due to the fragility of the thrust washers in the centre diff.
I guess the problem now is that many owners won't have a clue what the yellow knob was!
I stripped the old LT230 I removed from my 205k mile Disco2 last week in order to rebuild it and was surprised to discover that there was absolutely no trace whatsoever of the four differential gear thrust washers, not even a hint of a fragment. This is a high-mileage box which I've owned from new and has never been abused.
Post #928159 1st Nov 2021 11:28pm
