Home > Technical > Tuneful relay |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
Just trying to sort a noisy relay which is used in the circuit to power some scene lights from my aux battery.
When I switch on, there’s a high pitched whine from the relay. It also causes the lights to flicker. I can make it go quiet by holding it firm against the wiring socket at a particular angle but when I let go it returns. I can also play a bit of a tune by waggling it around. I’ve tried bending the connectors on the relay a little to try to make a better connection but this doesn’t work. Any suggestions appreciated. Click image to enlarge |
24th Oct 2021 4:45pm |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 400 |
Probably the start of a failing relay, best to just change it as Mo says 👍
25th Oct 2021 7:19am |
