![]() | Home > Wheels & Tyres > Best for Boost?? |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 ![]() ![]() ![]() |
That's an interesting comment! I was looking for the General Grabber AT3's but had to visit a farming friend today who owns two Defender 90's and a 110 and he swears by the Mitchelin Latitude and the Continental Cross Track AT.
The Mitchelin also has good ratings for wet conditions, road noise and economy. Sadly now the jury is out for me between the Grabber AT3 and the Mitchelin Latitude and price wise they are both within a few pounds of each other £130 > £133 John |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 ![]() ![]() |
I had the Continental Conti Tracs prior to the Michelins on one of the Puma 110's. When the Conti Tracs came up for replacement there were non available in the 235/85/16 size so I went for the Michelins. Good as the Conti Tracs are the Michelins are a much more comfortable tyre with no loss performance and are very good in the rain. Unless you are up to your bonnet in muck a la Camel Trophy antics the Michelins will see you through, including snow.
I had General Grabber (the old style) on one of the Pumas but the Michelins are a much more comfortable and quiet tyre. A very good all around tyre. Does not look aggressive but it is a capable tyre. I am pleased with mine. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
After two pages of replies (Much appreciated) to my request I've just ordered:
Five Mitchelin Latitude 235/85/R16's from Kwik-Fit Lowestoft for £700.75 fully fitted etc. Kwik-fit are giving 20 percent off these (and other) Mitchelin tyres right now. Thanks again to all of you that contributed ![]() John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 ![]() ![]() ![]() |
Good choice, you won't go far wrong with the Michelins, great tyre I have these too
Don't forget to let us know what you think of them. 1982 88" 2.25 diesel
Well today was the day ![]() What a difference driving home ... felt like the lord of the road! 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
On our two Puma 110 station wagons I have 28psi in the front tyres and 35psi in the rear (no heavy towing). 1982 88" 2.25 diesel
Hi Spudfan .... thanks for the tyre pressure comment. Kwick Fit set 30 and 38 psi's off their chart. I'll try their settings for a few days then deflate to yours and report back ![]() 2021 Defender 90 300Tdi SW (Blue/1994) |
Provided your Defender is not loaded to the gills or towing a loaded horse box you can go as low as 32psi in the rear. Land Rover regard the 28psi front and the 32psi rear as their "comfort setting". I use 35 psi as standard rear pressure. So for general everyday use the 28/35 will be fine. Even loaded with holiday gear it is fine. 1982 88" 2.25 diesel
