Home > Td5 > intermittent rear wipe parking
excossack
I have noticed the rear wiper doesn't always park when you turn off the wiper. I have used the same power feed to supply the power to the reverse camera (Green/White wire) when rear wiper does not park, also the camera does not work.
Also is this the same wire as the water in fuel warning light?
I am pretty sure its not the rear wiper as the camera stops working as well.
A fault in the loom ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #926189 18th Oct 2021 11:28am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Sounds like an earth problem as these things usually are. Check out the cluster behind the panel in the tub behind the relevant side. Trailer sockets can also be problematic as they get covered in crud, clean and renew connections. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #926320 19th Oct 2021 8:09am
excossack
Cheers Jeff. A job for the weekend I think 1999 Defender TD5 110
Regards
John M0VAZ
Post #926371 19th Oct 2021 1:07pm
