Home > Tdi > Freak minor breakage almost caused a crash
SimpleSimon
United Kingdom 1998 Defender 90 300 Tdi HT Rioja Red
Driving home from work today in the Defender, I turned into the road that links in to the road where I live, and ended up clipping the opposite kerb as I made the turn. Luckily nobody was nearby. It took me a second to work out what had happened, it wasn't some catastrophic failure of a major steering competent... The plastic shroud/cover on the steering column had come loose and somehow fouled the wheel and jammed it as I tried to straighten up! I managed to batter it back into its proper position, although I've now cracked it so it'll need replacing anyway.
No idea what caused this to suddenly happen, it looks like a "clam-shell" type arrangement which has split apart for some reason. 1998 300tdi 90 Hard Top. Daily driver, dog bus, shooting wagon and ongoing project!
Post #926285 18th Oct 2021 8:51pm
L110CDL
Good news that no one was hurt Thumbs Up
The plastic shrouding around the steering column comes in two half's and they are joined together with four long screw bolts and then the whole shrouding in secured to the steering column itself with three shorter screw bolts from underneath, hope this helps Very Happy
Seems like the screw bolts have come out / undone themselves Rolling Eyes Clayton.
Keeper.
Post #926291 18th Oct 2021 9:19pm
Dinnu
As Clayton says....
The 3 short screws that screw the whole shroud to the steering column are screwed into what is a counterbore in the plastic. On mine, the counterbore failed - probably because the whole binnacle which was also cracked was resting on the shroud caused the counterbores to fail.
A simple solution is to use slightly longer screws, and a large penny washer. This works, and probably the strongest. But cosmetically I did not like it.. so I flattened the inside of the shroud, and glued large penny washers with PU glue on the inside to re create the counterbore.
PS. On old Defenders, the 2 halfs of the shroud connect by 4 M4 screws with brass inserts molded in the top half of the shroud. On later Defenders, these were replaced by self tappings in the plastic. Some call it value engineering. I do not know when the transition happened. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926305 19th Oct 2021 5:21am
SimpleSimon
Thanks folks, I'll have to order at least the top half, as that's what I broke trying to make it driveable. I'll have a look when it's light and see if the screws/bolts are still in place or if they've come loose and disappeared. In which case I'll have to get some screws as well! 1998 300tdi 90 Hard Top. Daily driver, dog bus, shooting wagon and ongoing project!
Post #926306 19th Oct 2021 5:40am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
As above but on mine as well as the self tappers there is one machined screw that keeps the lower half to the column. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #926316 19th Oct 2021 7:52am
