Home > Technical > Heated seats
dcpallets
Heated seats
Heated seat in land defender 2014 won't heat. Tried swapping over, but still no go. Even though there is power coming through cables
Post #926091 17th Oct 2021 4:37pm
Dinnu
Have you tried with a multimeter on Resistance setting and see if you can read any resistance on the seat side connector? If the meter reads infinity ohms, then there is a broken wire on the seat itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926094 17th Oct 2021 5:04pm
dcpallets
Ive swapped seat with my own one but still no go
Post #926095 17th Oct 2021 5:07pm
Dinnu
I assumed you swapped driver with passenger. Are you sure there is power supply? You check voltage? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926100 17th Oct 2021 5:17pm
dcpallets
Its a friend landrover with faulty seat, i have heated seats in mine ans know they work. Yes checked voltage, it seems strange it didn't work with my seat base in
Post #926101 17th Oct 2021 5:22pm
Dinnu
Did his seats work on your Defender? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926102 17th Oct 2021 5:25pm
dcpallets
No it didn't nor did mine in there's. Its a bit odd
Post #926103 17th Oct 2021 5:31pm
barbel jim
Just the base you swapped ?? There’s a thermal cutout in the back part of the seat that the wires break on… then no heated seats lumbar or base. Theres a simple guide on repair on here somewhere. His base might have a burnt out element as well hence it didn’t work in yours
Post #926108 17th Oct 2021 6:02pm
Check for voltage drop at the fuse before and after connecting, if there is a big voltage drop then there is likely a poor common ground.
Hence voltage present with no load, but with load significant voltage drop.
Check the ground resistance too, it should be as close to zero Ohm as possible and usually with most multimeters bleep too.
If not or a high reading then poor ground.
Turn off power though when doing this step though.
Also check fuse is secure, and obviously no blown.
As mentioned already you can check the resistance of the elements too, but as you’ve swapped seats I’d say the ground maybe most likely culprit. $W33T $0U7H3RN $UG4R
Post #926110 17th Oct 2021 6:06pm
dcpallets
So you mean earth,as in main earth body strap and do you know which fuse it is
Post #926113 17th Oct 2021 6:14pm
