Home > Maintenance & Modifications > Soon to be 3UZ swap.... Maybe
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Hello all.
Could anyone tell me the depth of the TD5 tank (90) from the sender mount?
Going to be using an aftermarket sender and pump.
I want to use a WEMA Sender and I've got options of 225mm - 400mm.
Thumbs Up
Pic cuz' why not 4.0 V8 Defender 90
My Instagram
Post #925889 15th Oct 2021 11:54pm
Timbo
England 2008 Defender 110 V8 Petrol USW Tonga Green
Hey LJ I'm the one doing a 3uz-fe swap at the moment and I've sort of copied defendermatt's idea. Take out existing sender and put a pump directly into the swirlpot, I used the donor lexus's pump. I can take a photo if you like but see Matts build thread and mine is pretty much the same. I used cable ties instead of machining a bracket Laughing Rolling Eyes The lexus pump is same shape as the one Matt used.
Post #925990 16th Oct 2021 7:24pm
LJMARSDEN
hi Timbo, I'm following both yourself and Matts builds at the minute.
I want to go this route so I can use some aftermarket gauges and also to give me a reason to machine some more nice parts for the car.
so I was aiming to get the depth of the tank from the ring before I start stripping, because I haven't got my hands on a donor yet.
Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #925994 16th Oct 2021 8:04pm
Timbo
Mines a 110 but I can measure it tomorrow for you, I assume they'll be the same. Having said that the sender gauge I took out is spring loaded so compresses as you put it in to confuse matters Laughing Rolling Eyes don't you just love Land Rover? If you get a donor car rather than just the engine, which I would recommend, you can take off allsorts of stuff I.E. accelerator pedal, fuel pump, engine loom, radiator, electric fans ECU etc. Plus you can hear it running which is always a bonus. On a side note as I dropped my tank down to remove sender gauge the rubber breather pipe had perished and the over flow pipe from filler tube had also perished. This is not unusual apparently and a guy on this forum has done a really thorough fix I would look at if I were you, Keep in touch buddy all the best Tim Thumbs Up
Post #925999 16th Oct 2021 8:43pm
LJMARSDEN
That would great Tim, thanks. Don't worry about it really. The fuel senders have a "useable" reading or something along those lines anyway…
or I'm getting it confused with the tanks "useable amount" in terms of its capacity. Rolling with laughter
and yeah I've actually already done a couple of fixes around the tank already, one being the filler neck... Rolling with laughter
I'll be making a thread of where I'm at with the build soon(ish) so we can bounce ideas off each other
My Instagram
Post #926000 16th Oct 2021 8:50pm
Timbo
the auto box wires! Shocked
Where I'm at now.
I measred depth today and wrote it down on a pad which is still in garage Rolling Eyes It was either 230mm or 260mm from bottom of rubber washer to bottom of tank. I know that probably isn't much help but at least I made an effort Rolling with laughter M57 gearbox is ready to go on if you go down this route and get bit's off guy I did in Poland the kit was pretty good. Bottom 4 bolts were wrong thread but easily sorted. Tomorrow I'll be connecting gear box to engine Thumbs Up
Post #926127 17th Oct 2021 8:52pm
LJMARSDEN
I see you're making some progress Thumbs Up
Thanks for the info Tim - thats close enough for a fuel sender I think Thumbs Up
heard the japs engineering uses a lot of fine threads?
gotta say thats a funky looking flywheel Rolling with laughter
Also, what are you doing interms of electrical? I'm going to be getting a standalone loom and then send my ECU away etc. 4.0 V8 Defender 90
My Instagram
Post #926129 17th Oct 2021 9:00pm
Timbo
I was going to use Pheonix engine management. They have a facebook page. A guy off this forum I made contact with looked at their page and wasn't impressed with their MO so now I'm not sure. They wanted the loom off donor engine and would rewire with new cable, delete immobilser, remap engine and delete auto box. This is a stumbling block for me at the moment as mobile electricians seem hard to find Neutral
I'll burn that bridge when I come to it, which will be soon, in the mean time I'll be connecting gearbox tomorrow and if I get time offering it all up to vehicle. I also need to figure a way to make gear lever work. Big Cry
All the best buddy
Post #926130 17th Oct 2021 9:28pm
LJMARSDEN
I've heard otherwise about Pheonix and know of someone who is going to be using his products soon on a built 3UZ that'll be running big power.
I also got intouch with the guy and he's extremely helpful.
I'm going to be going to him for my loom as he seems more than okay in supporting his customers - he even provides videos demonstrating the looms he builds for people too.
With how long it'll take for my winchester gears products to arrive I'll probably have enough cash to spend on a link ECU too...... Fingers crossed.
which means BOOST! Rolling with laughter 4.0 V8 Defender 90
My Instagram
Post #926599 20th Oct 2021 11:21pm
Timbo
I got a quote from them with a link to video and the quote was very thorough in it's breakdown. I've no problem with price and was all set to go ahead but for some complicated reasons I wanted to speak to the guy personally and phoned, no reply so left a message, no call back. If you've heard good things that's good. I'm happy to give them a go if they can do what's required. I only offered someone elses opinion, who seems to know what's what regarding electrics about which I know nothing Rolling Eyes I'm at the point when I need a sparkie to look over stuff so need advice. If you use them let me know how you get on buddy. Thumbs Up
Post #926813 22nd Oct 2021 8:50pm
LJMARSDEN
Will do Tim Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #926818 22nd Oct 2021 10:01pm
