Home > Technical > 2014 puma dash info |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
No LCDs in those 2 locations. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
14th Oct 2021 11:42am |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1031 |
Do you mean LEDs?
14th Oct 2021 1:13pm |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 |
Maybe not explaining myself or not interpreting the answer right.
So on the speedo, the display lights up and shows mileage. Are you saying that on the rev counter in the same place it is just black plastic and is a blank? Same for the middle black panel?? |
14th Oct 2021 1:27pm |
Not sure what is behind the rev counter, but the center part is just black plastic.
There are a few, and also discuss in this forum, where they fit an UltraGauge in the center portion. Google UltraGauge Defender Puma. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Oct 2021 2:43pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1073 |
From the workshop manual. I think a similar diagram should be in the owner's manual.
I've seen (22) DPF warning, but never (27) low range. (16) will also show "oil service". (12) TC looks different with our DSC models IIRC. Click image to enlarge |
14th Oct 2021 6:49pm |
Thanks for correcting me, forgot about the dpf indicators. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
14th Oct 2021 7:18pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1997 |
Having a 2.2 i have a dpf, but have never seen the dpf regen light , 22 in the diagram, come up. Nor the dpf full light ( thankfully). I’m assuming 22 only comes up if you need a regen, not if a regen is happening.
Never seen a low range one either, I assume you would need a switch on the transfer box or High / low selector lever to illuminate that one and I’ve never seen one in either of those areas. |
14th Oct 2021 7:33pm |
Yes, the amber DPF light is a request to drive in a way an active regen can be done; threre's no light for passive regens. Had it come on once after a few hours of off-road crawling, preceded by a few hundred km of low speed driving.
As for low range there is a switch to tell the engine ECU about it (idle jack e.g.) and according to the diagrams the switch is connected to the instrument cluster, which then probably sends a CAN signal to the ECM. Maybe they thought the hi-lo gear stick's position is easy enough to tell (which it is IMHO, although I always wonder why I have to push it UP to select LOW range... ) |
14th Oct 2021 8:13pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 334 |
Even if you couldn’t tell the position of the stick, the high revs at low speed would tell you soon enough if you were in low range. Totally agree a low range indicator would seem to be pretty pointless.
14th Oct 2021 8:43pm |
@macfrank That is exactly what I was after. Thanks
And thanks all for your input. |
15th Oct 2021 11:36am |
