Home > In Car Electronics > Custom tablet dash mount for Puma |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
A tip for you... you can install a dash cam app and have more functionality 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
10th Oct 2021 11:58am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2054 |
How does the tablet deal with the heat from the vents behind it during winter ?
10th Oct 2021 12:23pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2249 |
Very tidy !
10th Oct 2021 1:29pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 888 |
oooh. It looks just like a Tesla.
Lovely job. |
10th Oct 2021 3:23pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1082 |
looks very professional. extra points for the Wunderbaum
11th Oct 2021 5:46pm |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 |
Should be far enough from vent to not overheat the tablet, so far so good...but I'll get back with a status in January |
15th Oct 2021 2:45pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
So velcro and slotting it into the vents is holding it in or have you screwed through the dash? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
15th Oct 2021 4:20pm |
Just slottet into vent and velco it on the front. That's it, no screws. Very stable. Let's see if induced torque will eventually crack the vent, but so far so good.
15th Oct 2021 9:58pm |
To address the smart question of lanh about how the tablet will hold the temperature of the vent.
Well, it appears that the tablet is not an issue, BUT adhesive of the scratch on the metal plate yes. Temperature of vent/sun softens the adhesive, and as I only put two narrow stripes of scratch, the weight of the tablet slightly slides the scratch down on the metal plate. My first solution is to increase surface of scratch, so weight/surface ratio will decrease. New larger scratch is 3M, maybe better quality. Let's see if that works better. Click image to enlarge Definitive solution if it does not work as expected: glue scratch to the plate (not the tablet) with epoxy adhesive or put some small screws through the top of the scratch. Agile/iterative custom product dev |
20th Oct 2021 9:08pm |
Good point. I try to avoid stick-on velcro as the glue always seems to become weaker than the velcro itself eventually... Or maybe I just didn't get good quality. 3M maybe better.
In a recent video of Grizzly n Bear Leigh said they had attached a flexible solar panel to the roof using "heavy duty velcro". I wonder what that is exactly or where to get it. |
21st Oct 2021 5:37am |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
Good effort.
I went the RAM mount way, absolutely brilliant, very stable, can change between cars, very strong suckers, just quite pricy. 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
21st Oct 2021 6:45am |
Opps double post 2015 RRS Autobiography SDV6
21st Oct 2021 6:46am |
Perhaps your mounting plate would benefit from a second plate that's spaced off the back by 10-15mm? The same principle as the safari roof on Series Land Rovers. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
21st Oct 2021 7:33am |
Thank you Darren that might be a solution. But may be the cantilever will be too important. Let's keep your idea in reserve should plan B and plan C not tackle the bug
21st Oct 2021 2:45pm |
