Home > Wheels & Tyres > Twisted wheels - balancing issues
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I’ve always had issues getting my wheels balanced. I’ve got Twisted 18’’ wheels with Cooper Discoverer AT3 285 tyres (previously BFGs). I am assuming it’s just a combination of a large tyre on a et0 offset that’s causing the problem.
Am I wasting my time trying to get them balanced again as quite a few have tried and failed? Would a 265s be better?
Post #925226 10th Oct 2021 4:20pm
Bluest
Just a thought, I’ve no experience, but have you thought of trying those dynamic balancing beads? 2007 110 TDCi Station Wagon XS
Post #925228 10th Oct 2021 4:42pm
carrotbay
Thanks, I hadn’t considered those.
Does anyone have any experience with balance beads?
Post #925231 10th Oct 2021 4:55pm
PCM
I had issues with the same wheels. Rang my local LR service centre, told them the issue and asked where they get mew tyres from. They obliged.
Took it to the garage (in this case was ATS) as they had a machine capable. Balanced them without issues for £50 a set of 5. Worth every penny.
Never tried beads, i'd try to find a capable garage first. Very Happy
Post #925234 10th Oct 2021 5:05pm
Co1
I’d second the garage bit. I had a garage that couldn’t get mine close to balanced and suggested it was down to the tyres being AT! It had shed loads of weights on! Took it to another who sorted it no problem using minimal weights. Smooth as you like now. That was BFG KO2 on twisted 16” 0 offset rims.
Post #925238 10th Oct 2021 5:22pm
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
These guys should be able to help. http://www.towcestertyres.co.uk/
They balanced my twisted wheels without issue.
Post #925300 11th Oct 2021 12:09pm
Likeomg
Could you let me know exactly which garage you used? When i went from 285 BFG to 285 Cooper's nobody could balance them very well... ended up going back to twisted who charged me 100 to balance them... have been holding off having them re-powder coated as didn't want to pay another chunk to have them re balanced.
Biggest problem is, most garages don't have a boss big enough to fit the twisted wheels, AM Newcastle even offered to balance them for me but couldn't fit properly on the machine.
Post #925302 11th Oct 2021 1:02pm
carrotbay
I tried Towcester tyres and they weren’t able to help and suggested I needed smaller wheels (!) as these needed an unreasonable amount of weights.
I’m going to try ATS at the weekend or a trip to Southam tyres who specialise in 4x4. I think it just needs someone with the patience try and if necessary rotate the tyre on the rim. Failing all that I’ll try balancing beads from Dynabeads and see if that has a good result.
If all else fails I’ll buy a set of Bowler wheels with a smaller offset and bring them down to 265s.
Post #925331 11th Oct 2021 5:04pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Likeomg
I run ATS in Hexham which must be close to the route between your 2 locations and we have centre bosses up to the size of a dinner plate. I only run 235s on mine but we have no probs with big HiLux wheels which have a big centre hole
Post #925344 11th Oct 2021 6:41pm
Likeomg
Hi Drakes,
Thanks for the info, i usually drive over the 686 when transiting between the two. im offshore at the moment and just purchased a L405 to use as a daily, gives me some time to do a few things on the defender, i've had a galv chassis in storage for the last 3 years now... ill get in contact in November and see about running the wheels up once i've had them blasted and coated.
Post #925415 12th Oct 2021 10:54am
I have a similar situation with my Blindos, my local dealer's balancing machine won't take them (it mounts wheels back-to-front using a nave plate which cannot be done with a Blindo).
I usually find that to start with the tyres are well-enough balanced to be fine, but as they wear (I run KM3s) they get worse. When they become intrusive I dump twice the recommended dose of Dynabeads in and it works miracles.
You may ask why I don't put the beads in on day 1. The answer is that it worries me that they will form a congealed lump with the bead lubricant, so I like to leave it a while. I've never heard of this being a problem however.
Post #925424 12th Oct 2021 1:00pm
L110CDL
I've never tried beads but i use my local ATS and just recently for balancing the Blindo's which they had no problems and they were spot on Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #925697 14th Oct 2021 8:39pm
