Home > Puma (Tdci) > Diff engaged light. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I have replaced my diff lock switch from below, 2.2. I had to chop a 19mm spanner though to be able to reach and rotate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
11th Sep 2021 5:43pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
You can do it from below, a very deep socket helps, but needs space to fit wires in it to! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Sep 2021 7:20pm |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
Many thanks for the reply’s gentlemen will try & source one in Spain.
12th Sep 2021 7:52am |
i have problem with one that was slow to operate removed it and placed it in cup with paraffin and has worked for a long time now
12th Sep 2021 8:12am |
That’s not a bad idea, if it were accessible from the top ( if it didn’t mean removing the Planar) I’d give it a go.
But beings I’ve got to do it from underneath I think I’ll try & get one in Spain. Does anyone have a part number for the 2.2? |
12th Sep 2021 8:18am |
also known as High/low on Discovery 2
IGM500011 |
12th Sep 2021 8:26am |
Many thanks Dorsetsmith, much appreciated.
12th Sep 2021 8:31am |
Just an update, did this the other day & as said a cut down 19mm works a treat. It took as long to change the sensor as it did to try & undo the clip into the loom!
One thing I did with ours was to remove the floor pan under the drivers seat so you can see over the chassis rail which makes it much easier. |
7th Oct 2021 7:58am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2108 |
Sounds like you are trail blazing for us all in your on the road repairs and how to overcome them !
Been reading the Blog of the trip and its really giving me itchy feet!!! hope your troubles are small and easy overcome Happy travels Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
7th Oct 2021 9:38am |
took me ages to get the electrical clip undone too! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Oct 2021 3:03pm |
Thanks Gary, just need to get the spares ( when we meet up with our travelling companions) & all will be good. |
8th Oct 2021 4:44pm |
