Home > INEOS Grenadier > Reserved
Page 6 of 13 <123 ... 567 ... 111213>
Thanks but can't do anything with your confirmation number ~ I need the last four, or if you prefer just two of them, such as "45xx".
Looking at your BST timing, I'm going to guess your number is greater than 2000 but less than 2500?
Post #924141 3rd Oct 2021 5:38am
Hweebe
Australia
Very good prediction
Confirmation #: 00052622xx
Post #924143 3rd Oct 2021 5:51am
Hweebe
Australia
This reddit thread also contained some good info:
https://www.reddit.com/r/ineosgrenadier/co...;context=3
So is it confirmation numbers or invoice numbers we should go off? Smile
Post #924144 3rd Oct 2021 5:54am
I'll check that thread out next Thumbs Up
Actually scratch that ~ it appears to require an app to read described as sub optimal in the reviews.
OK ~ now in via Google...
Can you extract any data from it and cross post here?
I'm liking confirmation numbers personally ~ it is the number generated at the point you pay. Invoices are following several hours later, and who knows what order they are being processed in?
Post #924148 3rd Oct 2021 6:10am
Supacat wrote:
LandRoverAnorak wrote:
Ours is 57xx at 8:31 yesterday.
That's the first one not computing - but it does fit exactly if the time was one hour earlier?
Hmm, that's odd. I've just checked and both the number and email time are definitely correct:
 Darren
Post #924176 3rd Oct 2021 8:28am
I'll be interested to know what the towing gear will comprise, though, particularly give the number plate position.
There was a towing arrangement on the vehicle recently imported into Australia :
<snip>
Seems odd that the online Configurator appears to miss such a fundamental item off from the get go?
Thanks for all of that. As somebody else mentioned, it would be nice if they homologated a 2 inch receiver but I somehow doubt it.
blackwolf wrote:
A NATO pintle will require that the number plate is relocated.
You read my mind Laughing Darren
Post #924178 3rd Oct 2021 8:32am
Reverse engineering the solution - I'm going to suggest it's the difference between GMT and BST.
Post #924179 3rd Oct 2021 8:34am
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
Reservation placed and confirmed on email at 11:03. Number 000xxx74xx 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone )
2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone)
Post #924183 3rd Oct 2021 8:46am
Bev - that's not a fit with the data set currently, but error may lie elsewhere...off to check if I've recorded correctly elsewhere.
Scratch that - works perfectly - my cut & paste error Embarassed
Post #924186 3rd Oct 2021 8:58am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Ours is 22xx at 7:49 on 30th Sept West Australian time if that helps! 1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'.
2000 Defender 110 TD5 Xtreme.
2015 Defender Heritage 90.
Post #924216 3rd Oct 2021 12:17pm
stng110
Australia
Do you have a ploy update?
Post #924283 3rd Oct 2021 7:52pm
Bev
Thumbs Up When I glanced at the initial graphs the times and confirmation numbers fitted in nicely. It will be interesting to see how the trajectory plays out. 2002 Td5 | 90 County Station Wagon | Oslo Blue
Post #924288 3rd Oct 2021 8:26pm
Update - filled in a few gaps and confirmed upper limit of 8xxx is actually 83xx.
Unsure if we have any known 1xxx confirmation numbers and no 0xxx confirmation numbers so reservations are only known to start at 2xxx currently.
Post #924317 4th Oct 2021 7:38am
Huttopia
Mine is: 00052xxx at 8.00 on 30/9/21
Post #924326 4th Oct 2021 8:04am
Huttopia - If your full reservation number is in the format #000526XXYY, then I'm looking for the XX numbers.
If 08:00 is BST then I would guess it starts with a 6?
Post #924333 4th Oct 2021 8:37am
