Home > Tdi > HELLO and rear wiring loom |
Hello and welcome to the forum
Start with the easy one. The cable with 7 wires is likely to be the trailer wiring harness that someone has put crimp bullet connectors on. The extra cables you have are for a left hand drive Defender. LR just added the the extra wires to save on having a left and right hand wiring loom. The good news is that if you ever want to add extra reverse lights you can just use these connectors. |
29th Sep 2021 2:00pm |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 151 |
This might help you ... There's also a connector library on the site if you've not got a copy of the workshop manual
https://www.lrworkshop.com/wiring-looms/de...s-loom-110 Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
29th Sep 2021 8:09pm |
Leolandy Member Since: 29 Sep 2021 Location: Rutland Posts: 2 |
cheers both !!!!
I thought i was going mad with all these spare connectors but that makes prefect sense. Just the wiring to go, cant be that bad / hard |
30th Sep 2021 9:53am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2248 |
The other wires are probably for heated rear glass and rear wiper. The bunch of 7 is as geobloke has said, for towing electrics.
30th Sep 2021 6:43pm |
