Home > Technical > Rubber or Leather Rear diff seal?
Rabbitwabbit
United Kingdom 1997 Defender 110 300 Tdi CSW Stornoway Grey
Hi all - quick question...which do you prefer - the rubber or leather rear diff pinion seal? My 1997 defender 110 currently has what looks like a reasonably new rubber seal fitted, but it's already leaking having had a reasonably easy life! does anyone have experience of both types of seal? Which would you recommend and why?
Post #923032 27th Sep 2021 3:18pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I used a leather seal in the series one front hub. Worked quite well! I didn't know that there was one for the diff pin oil seals as well?! 1953 80"
1987 mini city e
2011 90"
Post #923098 27th Sep 2021 8:18pm
Rabbitwabbit
Hi Mr James - I didn't know they made the leather seals for the diffs either until yesterday when I stumbled across one. Part number AEU2515G. Most sites seem to stock them, but Craddocks displays and describes the part very well.
Post #923149 28th Sep 2021 7:44am
jst
How many miles?
Sounds more like worn input shaft if new seal not doing its job. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #923280 28th Sep 2021 8:37pm
Rabbitwabbit
Hi. Total vehicle mileage is 68K - so not high for a 1997 vehicle. Without pulling it apart I can't see the overall condition of the shaft, but I wouldn't have expected massive wear on the component at this mileage.
Post #923406 29th Sep 2021 1:03pm
Dinnu
Or seal fitted wrong way? Or breather blocked? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923415 29th Sep 2021 2:01pm
Rabbitwabbit
Seal is correctly fitted and breathers are fine. I'm thinking that if the vehicle has been stood for a while, then the shaft could have rusted or pitted slightly or the rubber could have become hard due to lack of use - then, as I've started using it regularly then it's started leaking. I'll pull it to bits, give the shaft a clean up and replace the seal and see how it goes. if it still leaks, then I'll look to replace the shaft.
Post #923436 29th Sep 2021 4:05pm
Rabbitwabbit
Eventually I replaced it with a rubber seal and so far it seems to have done the job.
Post #926510 20th Oct 2021 2:57pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Have had a leaky rear diff pinion on my 110 since I got it in 2015 despite a few attempts to remedy it with various rubber and leather seals and giving the flanges a serious clean up. Replaced the flange with a new one and fitted a leather seal around 6-12 months ago which appeared to finally fix it, but noticed in the last few weeks that the diff nose is looking 'damp' again, maybe not the permanent fix I was hoping for.....
Before anyone suggests it the breather is clear with a new pipe ran from the cleaned axle banjo fitting inside the body to gutter level.
Post #926579 20th Oct 2021 8:34pm
Rabbitwabbit
Hi - thanks for your response. I've been working my way around the various bits of leaks etc., and I finally feel like I'm getting somewhere (just the 1 'serious' leak from the transfer box idler shaft!). Once I've finished, then I'll probably need to start all over again - keeping the leaks at bay is like painting the Forth Bridge!
Post #926666 21st Oct 2021 1:01pm
Timo K
Finland
Had a leather type seal in mine, local specialist recommended replacing with a newer rubber type seal, so they fitted the newer type flange and rubber seal, been happy with it so far.
Post #927566 28th Oct 2021 1:14pm
