Home > Technical > 2.4 TDCi Exhaust manifold fittings - questions |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17549 |
Possibly, interesting thought.
13th Sep 2021 7:55pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3470 |
Ok, so it provides angular alignment as both X and Y alignment is already determined by the smaller hole in the manifold.
That is a very strange way of getting alignment. Probably an elongated hole (12.9x10.3) on the #1 top hole would have done the job better from an engineering perspective, and removed one part from the spares bin. But maybe Ford found that it would be cheaper to drill than mill, and create a plastic insert. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
27th Sep 2021 9:54am |
I think LR found another way to remove the part from the bin, by simply not fitting it. It wasn't there on my 2007, and it wasn't there on my spare engine (ex-2009 write-off). Both engines, as far as I know, had never had the manifold removed before. The other possibility is that the plastic spacer simply burns away over time! |
27th Sep 2021 11:00am |
