![]() | Home > Maintenance & Modifications > LED Bulbs in side/indicator lamps - MOT fail? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
There is nothing the Testers' Manual at present about LED bulbs in sidelights or indeed any light units other than headlights, whereas there is a specific check for LED bulbs in headlights.
Although technically not allowed, I do not believe that having LED bulbs in side- or tail-light units designed for incandescent bulbs would result in an MOT failure under the current rules. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
Thanks Blackwolf. Any suggestions on which bulbs to use, are some better than other in terms of light output/direction or are they much of a muchness?
Thanks Col |
I can't really answer that, but what I can say is that when I bought my highly illegal but fantastically good LED "H4" headlight bulbs from Classic Car LEDs I bought the equivalent LED bulbs for the sidelights and brake/tail, reverse, and rear fog. I have been extremely happy with them, they work well, look good, and complement the headlights well in terms of colour.
I didn't bother with the indicators since personally I don't like LED indicators at all, plus there would likely be issues with my trailers. |
Thanks Blackwolf, much appreciated.
Last question I promise! Did you go for warm white or bright white? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20634 ![]() ![]() |
The same would apply to the side repeaters as headlights. If they are sold as ‘E’ marked LED units then they are legal.
(And is present on the lenses). If an LED cluster is fitted to a standard side repeater housing that isn’t legal. The latter may still pass an MOT though but isn’t ideal. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
I went with the cool brilliant white since the warm white looks daft with LED headlights. I don't know what it will look like when the MOT comes, since it will either get the H4 candles back or it will get Truck-lites. I haven't decided yet. |
