Home > Td5 > Intermittent Starting Issue
bankz5152
Hey,
So my 110 has developed an intermittent starting issue which appears to be getting worse.
On occasion it will take a good 20 seconds to start, cranks fine then sounds like its trying to fire but cant quite get there. However will start if I put my add throttle, however If I lift it will chug a little then die.
That said hot or cold doesnt seem to matter. Strangest part is it will sometimes start fine, do 40miles on the mway, then I stop for coffee and its hard to start again. Same as above.
Injector seals where done last year, roughly 10k ago. Genuine LR
Starter 3 years ago, Denso
Alternator 2 years ago, Denso.
Battery is charging - 14.4v when running also have split charge. Both batteries charging as they should.
Crank sensor swapped out for a Lucas, still the same.
Fuel filter housing is GORE 4 years old. Filter is 3 months old, Mahle. Correctly purged when installing.
MPG remains the same. Not leaking fuel as far as I can tell.
FPR is around a year old - genuine LR as well.
Fuel pump is getting noisy, however been like this for a while now.
Any other suggestions? Instagram @defender_ventures
Empire Tuning - Agent
Post #922127 20th Sep 2021 6:14pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Suggest you…1 plug it in and see if there are any codes. 2 check for oil in the ECU plug
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #922416 22nd Sep 2021 8:34pm
bankz5152
None and dry. Instagram @defender_ventures
Post #922417 22nd Sep 2021 8:47pm
4RF RDS
Boo! That sucks…. Have you checked the duck valve in the fuel filter head? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #922418 22nd Sep 2021 8:56pm
lightning
l had exactly the same issue with our TD5 90
After changing the injector seals, fuel filter housing, battery, FPR, MAF unit, injector harness, and no change
The fault was the STARTER MOTOR
It was working, but producing some sort of voltage spike or interference that was messing up the ECU and causing the intermittent starting issues.
Post #931624 28th Nov 2021 10:04pm
geobloke
Similar to the above statement. Fitted a Britpart starter motor and then began having horrendous starting problems as with yourself. Replaced the starter motor and bobs your uncle all A-OK once more.
Having said that how bad is the fuel pump? I had a noisy Bearmach pump in Miffy that over time got noisier and then the engine began to do the same as you describe. Turned out the pump was not making the required fuel pressure. I would try and pressure test the pump first. See whether that is behaving. If it is the pump only buy VDO… Thumbs Up
Post #931647 29th Nov 2021 8:02am
jimbo55
I’d start by changing the pump, if it’s noisy then it’s certainly on its way out and even if it doesn’t fix this issue then it will most likely stop you getting an issue with it further down the road. - not cheap but go for a genuine VDO one and not aftermarket
Does it crank over at a reasonable speed? I.e. a speed that it should start at?
Post #931653 29th Nov 2021 8:49am
roel
What is the voltage while Cranking? If the voltage is too low the ecu will stop working and you get no fuel injected.
As asked before how is your cranking speed. The grease in the reduction gears can get sticky. I could hardly turn it by hand. I changed it to normal bearing grease and it cranks a lot faster. Roel
2003 90 Td5 (2009-now)
Post #931751 29th Nov 2021 8:18pm
