Home > Maintenance & Modifications > Chinese Diesel Air heater Install
Page 2 of 3 <123>
Gilloverland
Not really started the exhaust yet, the booklet (in really bad English) says 2m max exhaust length but I've seen plenty fitted into boats with longer.
At the moment I'm thinking similar to the intake:- a u bend just before the silencer and a rubber/cork bung or perhaps a screw on cap just for wading.
I've had a good play with it today and Im really impressed, it starts up pretty quick, gets the whole of the 110 warm in under 10 mins and isnt that noisy either (It does get quieter still if I put the muffler into position when its running).
Post #763511 14th Mar 2019 8:47pm
Gilloverland
Pretty much finished this install now, just the air intake pipe to neaten up in the engine bay and I'm planning a slightly bigger, alloy tank.
The exhaust all done:
The other thing I did was to wire the 'on' switch to a little control box provided by this company:
https://www.gsm-uk.net
Basicly a relay controlled by a pay as you go sim card, I can now 'text' the heater and in under 15mins the 110 is lovely and warm and the windows defrosted
Post #767103 5th Apr 2019 8:14pm
selectcase
United Kingdom 1998 Defender 110 300 Tdi CSW Alaska White
Great post This is just what I was thinking I needed the other day Thumbs Up
Post #767537 8th Apr 2019 6:16am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I've been pondering using a false second snorkel when I come to getting one that feeds just the air intake to the heater. Should make wading etc not a issue as far as the inlet is concerned.
I was debating if the exhaust could be run up inside it too, but I imagine the heat of the exhaust would melt the snorkel if it was to touch the plastic snorkel. I did debate doing like a combi boiler and putting the intake inside the exhaust but I imagine a combi boiler flu runs a lot cooler 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #767760 8th Apr 2019 9:54pm
Gilloverland
The exhaust does get pretty hot (some people on the facebook group have fitted heat exchanges to run showers etc).
The main problem would be not creating too much back pressure in the exhaust, the manual says 2m max but you could probably increase that with a bigger bore?
Post #767959 10th Apr 2019 7:05am
Canadude
Canada 2003 Defender 90 Td5 SW Tonga Green
excossack wrote:
I can see the pics now I am at home. Under the rear seats is my current thinking. I did have the thought of engine bay and then duct the warm air in via the heater/blower feed.
Question is if you took this plan any further than thinking about it? I am wanting to do exactly that and I’m having difficulty finding anything Online related to anyone else doing it… If you know of any information about this I would love to see it
Post #922004 19th Sep 2021 5:19pm
HenrikSw
Sweden
Hi,
is it possible that you could share the Facebook group and the ebay contact that was mentioned earlier? Bow down
Thanks
Henrik
Post #922073 20th Sep 2021 12:00pm
jst
I have an air heater .mounted under 110 rear seats Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #922145 20th Sep 2021 8:52pm
Devon-Rover
Same here ^^^
Makes winter mornings enjoyable
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #922246 21st Sep 2021 4:49pm
90 Dreamer
Is that Diesel or Electric powered please??
Post #922272 21st Sep 2021 7:23pm
camelman
They are diesel fuelled.
Post #922278 21st Sep 2021 7:51pm
Dr Meat
Hi Gilloverland,
Great job, I’m considering fitting a Lavaner heater under my cubby in my 110. How do you find the hight of the cubby after fitting this? The last thing I need is one more thing to bash my elbows on when I’m driving Very Happy
Post #979200 22nd Jan 2023 9:27am
landy andy
I’ve got the same box under my cubby box, with a subwoofer in, and find the height far better than standard, and I’ve even got spacers beneath it, to allow the sound out. As standard the cubby is far too low to be used as arm rest in my opinion.
Post #979221 22nd Jan 2023 11:48am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
We have it in the Nakatanega console and the height is better than without IMHO. We removed the original wooden wedges underneath.
But yes, elbow... we had to move the cubby box forward by 2 or 3 cm, so first try it out and then may be drill new holes.
Post #979235 22nd Jan 2023 3:03pm
Dr Meat
Hi macfrank,
Thankyou for your reply, if I go ahead with this heater idea, I think I will use a MUD heater cubby box as I did want the Nakatanega console but I spoke with Brendan from 4x4 overlander who seemed really helpful but I emailed him twice and had no response. Also I want to still be able to fold the rear seats & I was under the impression that the Nakatanega pushes the cubby towards the rear & gets in the way of the seats.
Post #979244 22nd Jan 2023 5:23pm
Page 2 of 3 <123>
