![]() | Home > In Car Electronics > Permanently Connected Compressor |
Dagonet Member Since: 15 May 2019 Location: London Posts: 10 ![]() ![]() ![]() |
Hi Folks,
I'd Like to have my compressor connected all the time rather than have to open up the battery compartment and connect the crocodile clips every time. What would be the best way to do that? This is my compressor: https://www.ebay.co.uk/itm/202981346559 Voltage: DC 12 Volt Amperage: 45 Amps Power: 540w My reasoning is that I'll be more inclined to air down if I don't have to faff to air back up. Any help appreciated. |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1443 ![]() ![]() ![]() |
I've seen a great way to ease the air up process.
The guy had made up lengths of flexible air line in a circuit, a H arrangement. There were clip on valve connectors at the 4 ends, to fit on all 4 wheels. The compressor connected at one point in the circuit, near to an adjustable pressure valve. To air up at the end of the trail, he connected the compressor to the circuit, clipped it onto all 4 wheels, switched it on. Then got out his coffee and sandwiches, and had a chat while his tyres were all blown up to the same preset pressure! ![]() We were very impressed by this, not having to connect the compressor to each wheel. He'd been using the method for a long time and reported no issues.This was in the USA, where airing up and down is much more common. Doing it every day for a week could become a real pain. Depending on the road miles between trails, some just left it at the lower pressure all week. |
Thanks for the advice Dinnu. Your description is so clear I don’t need a diagram! Very much appreciated. |
Very fancy, I’m not at that level yet! |
I've seen that sort of system before but it always strikes me as a bit odd, as tyre pressures are usually different, front and rear. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Easy to get round that.
Put a valve in the system to shut off the front half. Then continue to raise the rear pressure. The main use was to quickly get from 16 psi to 30 psi for 30 or 40 miles blast down the highway. At the end of the week it would be prudent to check the condition of each tyre and set the pressure accurately before setting off for a 1000mile journey home. Last edited by DSC-off on 18th Sep 2021 8:37am. Edited 1 time in total |
I appreciate that it can be done. I'm just not sure that it is. I'm also not sure that it's significantly quicker than doing each tyre separately. Unless the compressor has a huge reservoir, it's output will remain the same but just split over four tyres. I admit that it looks cool though, and like the idea of a plumbed in airline. Darren
It was no quicker to do all 4 together, just less trouble. Have a break, and leave it to it.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3477 ![]() ![]() ![]() |
I missed an even simpler connection, by for example using an Anderson connector, example fitted outside of the seatbox, and replace the crocodile clips with the Anderson counterpart. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
This seems like the best option, and the least work!
I did something similar (but not an Anderson) but to connect a battery maintainer for when I am not using it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
