Home > Maintenance & Modifications > Advice
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
Advice
My Defender is going in to my friends workshop for 2months when I go back to work. It’s done 115000 2.2
I’m getting it serviced and mot oil pump and injectors done. Is there anything else I should be looking at
Post #921765 16th Sep 2021 11:20pm
MichaelE
Game of Thrones. That's worth a watch if you haven't already.
Post #921770 17th Sep 2021 4:28am
Co1
Depends how far you want to go. Has it had a clutch before? If not you’ll be surprised at just how much that tightens things up. If your doing the clutch then the output shaft will most likely want doing again. Just had mine MOT and needed discs and pads on all 4 corners at 83k (never been done before), but the MOT will tell you whether this is needed. You can go as far as your wallet allows!!
The good news is that it won’t have depreciated much so you can justify keeping it in great condition. That what I tell the wife anyway!
Post #921771 17th Sep 2021 4:44am
LR90XS2011
rust prevention if not already done,
brake fluid and coolant if not done in last 3 years DEFENDER 90 TDCI XS,
Post #921773 17th Sep 2021 5:28am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Get the DPF removed… Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #921775 17th Sep 2021 5:56am
chris d3
DPF and EGR will be getting done. Output shaft is on the list still on my original from the factory.
Chassis has been done all brake pipes flexis discs and calipers were done at 98000
Post #922290 21st Sep 2021 11:53pm
