![]() | Home > Technical > LT230 whine on over run after oil change |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
I think there’s a debate on here as to whether you fill with specific amount (2.6l I seem to remember - but do check) or up to filling hole, and what the results are after. Which did you do? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Filled her up by volume, but that did end up just a shade below the hole.
Sure someone will advise on oil type etc. Interesting as I’m doing mine today. Could it be something else in/around the box? Monsieur Le Grenadier
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 665 ![]() ![]() |
Are you sure it’s your lt230? Whine on overrun tends to be diffs as most likely culprit. You could pull your propshafts one at a time and test drive to eliminate either axle from the equation. When taking the rear one off, remember to make sure your handbrake cover screw is tight.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
75W90 is what the manual states.
I had a whine for a very long time, but was constant. Turned out to be the handbrake shoes rubbing on their sides against the drum. Old handbrake mechanism though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Swapped the oil out today after about 1000 miles. I found a single piece of metal in there, along with a small amount of filings on the magnet. The piece is as per the pic. Clear machining marks on one side and not on the other. I sieved
the rest of the oil and found nothing. If this were a gearbox at work I wouldn’t be over worried about the single piece of metal, but the oil looks a bit dark to me. It doesn’t smell bad. Any thoughts? ![]() Click image to enlarge ![]() Click image to enlarge |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 774 ![]() ![]() ![]() |
For 1000 miles it looks dark to me Col. Rgds.
Chris |
I thought it was a bit. Test drive in the morning so I’ll know whether it is still whining. The synthetic oil that came out was body temp to the touch as it had only been sat in the drive an hour or so, the mineral oil that replaced it was noticeably thicker at around 25c. Time will tell.
Perhaps the synthetic oil had more detergent and has cleaned some old muck that was clinging inside. Fingers crossed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Cheers Dinnu. Here’s hoping!
20 mile test run this morning and noticeably quieter. Interesting!
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
Was it EP75w90 you used initially, or manual transmission 75w90?
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
Interested to hear what oils you put in before and after! > 110 XS Double Cab
There’s a question. I’ll have to check, but what is the difference and what would the effect be? Cheers Col |
