- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
dorsetsmith
Find out witch headlight wobbly one or both remove headlamp finisher check head lamp bezel have all three head lamp fixing clips and screw in place and all three screws are screw home as this holds headlight in to bezel
also make shore that bezel is fix with one screw to headlamp body ( this is plastic moulding in-between bezel and wing ) two more screw should be slotted in to the bezel these are the adjustment screw up and down side to side try not to adjust then
also check that your speaker head light have no loss parts inside
you may find that bezel has rusted and fixing broken off
the video is good
9th Sep 2021 11:19am |
NickMSM
Many thanks - Just had a chance to have a look at it, turns out the top adjustment (12 o'clock) on the body is threaded so the screw is pulling through. New body ordered
10th Sep 2021 11:33am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
