Home > Maintenance & Modifications > Cruise control with max speed setting |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 889 |
I'm looking at the kits to add cruise control to my puma.
Before I take the plunge does anyone know of a kit that does cruise control but also like most modern cars allows you to set a max speed. I find on rental cars I just set this to 70 ( ) and then the accelerator won't allow you to go more than this unless you floor it. It's arguable far better than cruise that is only good on empty roads and if you're not careful has a tendency to drive you straight into the back of the car in front. I doubt it's been made as a retrofit, but wanted to ask the forum. Cheers PCM |
5th Sep 2021 6:41pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
The CanM8 cruise control has this. Roaming around 🇳🇴🇨ðŸ‡
5th Sep 2021 6:56pm |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 259 |
Hi PCM
I believe the John Gold cruise control system has a speed limiter function built into it but only for the puma defenders. Give Conrad Anderson a call they are very helpful. https://www.conrad-anderson.co.uk/products...se-control |
5th Sep 2021 7:25pm |
I just love this forum. Was going to spend more on an inferior system. Not any more.
Many many thanks. |
6th Sep 2021 4:43am |
