Home > Modifications & Maintenance (L663) > Fog lights retrofit |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
Hello Marco,
I think you've figured it out. Supposing the front main connector is all the same. You can check your left handle by the steering wheel, towards the front it activate the front fogs, rear are the foglights behind. If it will work, I think, but just try and let us know. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
4th Sep 2021 8:42am |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 74 |
I retrofitted the fogs. It’s a bitch in the arse!
You need the front parking sensor fog light harness. You need to pull most of the bumper off. You need a turn signal stalk with the front fog lights switch already in it. You need to pull your steering wheel. You need to run a signal wire from the front harness to the canbus bcm in the passenger footwell. You need to edit your ccf files with a defender with the fog lights and update your defender with the Bosch DOiP mastertech tool. You need to download pathfinder, hook up the tool, push your ccf changes. After all of that it will work. Oh also you need to run a chassis ground to the main fog light parking sensor harness too. You also need the fog lights. Also you need to dremel out the grille which covers the non fog cover so the fogs will shine through. Good luck! 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
18th Dec 2021 9:05am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 172 |
Hi Mark
thank you very much for your report. I solved it by manufacturing a harness for the fog lights, connected everything to a relay and inserted a new button for ignition, your work is fantastic but here in Italy no one was willing to update my ccf with pathfinder, therefore impossible !! !! Click image to enlarge |
18th Dec 2021 3:02pm |
