Home > In Car Electronics > Wiring in Speakers
CalumD23
United Kingdom 2013 Defender 90 Puma 2.2 HT Tamar Blue
Wiring in Speakers
My 2013 Puma has come with the holes/grills for speakers, but no speakers themselves. However the attachment for the radio head unit is sitting behind the dash.
Is this normal? Is this likely to indicate that there is wiring for speakers lurking somewhere, or am I likely to have to wire speakers in myself?
If doing it myself, is there a good guide anywhere or is it advised to get it done professionally?
Thank you.
Post #919225 30th Aug 2021 3:24pm
donmacn
I'll start by saying I've no experience of cars that new.
However I'd have thought that if you have the ISO connector behind the dash, then you'll have the wiring to the speaker locations.
But mainly I thought I'd say that this is reasonably straightforward to do yourself if you're a wee bit handy, especially with the ISO connector. It should be a case of choose your head unit, plug it in, and connect the speakers.
Then of course you're at the beginning of a long dark rabbit hole, where you start to investigate sub woofers and amps and other speaker locations.... or maybe that was just me. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #919244 30th Aug 2021 6:41pm
Oldowner
I had a basic spec Puma 90 with no radio as standard. All the wiring was present - ISO connectors for the radio and speakers, along with wiring and plugs for the dash mounted speakers and the optional tweeters too.
The standard 4” dash speakers are available for next to nothing. The optional tweeters are exactly the same as the Freelander2 tweeters which can be had off eBay for £20.
Post #919265 30th Aug 2021 9:44pm
Gasket
Hi - yes its normal. On lower spec models they came from the factory with what they called "radio preparation" which means all the wiring and aerial are there but no actual stereo.
Its actually quite smart as you can fit all 4 speakers, plus the tweeters and the head unit just by plugging them in.
Mine is exactly the same and I found all the connections tucked neatly under the covers.
The only issue you might have is that while the rear speaker wiring is there, there is a link missing between the grey plug near the clutch cable and the iso plug so the rear speakers didn't actually make any sound. Paul at LR Connectors made me a simple plug in loom to join them.
Post #919272 30th Aug 2021 11:23pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
That extra connection sounds like what I am missing, is there an official Land Rover bridge cable, or is only option aftermarket? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #919282 31st Aug 2021 8:01am
CalumD23
Great knowledge - thanks everyone.
Will keep looking on eBay for standard speakers and tweeters - if you see any of the 4" please let me know, I'm not having any luck (or am looking in the wrong place).
I have a Hard Top so no need for rear speakers!
Post #919450 31st Aug 2021 11:48pm
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Have you seen this auction? ...
https://www.ebay.co.uk/itm/174988985567?ha...Sw3K5hcql1
I got a set of four earlier this week from eBay ... try just searching "Land Rover Speakers"
Good luck
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #926831 23rd Oct 2021 12:22am
Race.it
Wrong thread Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #926835 23rd Oct 2021 4:42am
