![]() | Home > Td5 > 04 td5 no start and alarm not working. |
You may have lost power to the AS10 alarm unit as you can not communicate with the unit and you have no dash light
check fuses to start with and also 12v before and anther fuses ( make shore you ground and 12 v + at alarm unit plugs ) under seat fuse box fuse 7 and 6 passenger fuse box fuse 8 only powered with ign switch on also check earthing from battery to chasse and down to transfer box and between chasse to the bulk head under land rover Grey connector AS10 pin 12 ground in and Pin 25 battery + in ![]() Click image to enlarge green connector AS10 Pin 11 ground in ![]() Click image to enlarge |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 ![]() ![]() ![]() |
Thanks for the help. All fuses were good. I disconnected the battery for a bit and now as10 is working! 04 110 TD5
