Home > Puma (Tdci) > I found a loose cable in the engine
SVX110
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Galway Green
Hi guys!
Do you know what this loose cable is for?
Post #919095 29th Aug 2021 3:01pm
dorsetsmith
wire colours ?
Post #919098 29th Aug 2021 3:23pm
SVX110
One is fully orange and the other one is orange with a black strip
Post #919100 29th Aug 2021 3:32pm
LR90XS2011
could it have been for the engine breather pipe warmer, has the vehicle been somewhere cold? DEFENDER 90 TDCI XS,
Post #919101 29th Aug 2021 3:41pm
SVX110
The car was exported to a tropical country about 4 years ago, so since then it has only been in hot places. before that it was in Brighton and it was only used in summer.
Post #919105 29th Aug 2021 4:04pm
dorsetsmith
Can not find O and OB as a twisted pair on both wiring diagrams for 2.4
I would make safety free ends and trace then back the start
Post #919107 29th Aug 2021 4:06pm
Don’t quote me as this being accurate but in that area and being two wires I would suggest clutch switch.
From the video I can’t see the clutch switch present, looks like instead of doing the neat mod I did that someone has just cut the connector off and twisted the two wires together to [close the circuit] which is what a [Puma requires] unless an active working clutch switch is present.
I would tape it up for now as is to isolate it, then buy a male and female 2 pole junior power timer connectors. Then fit a wire loop to close the circuit neatly and tie aside.
I can’t remember which side is M or F but this is what I did.
As I said, this is based on presumption, but check the wiring colours off against the clutch switch wiring colours, this is what I am fairly sure it may be.
You need to keep the circuit closed for now I.e. wires connected together or you’ll have big problems driving it.
Checking the wiring colours off of a LR wiring schematic against them will give you 100% accuracy as to if it is indeed the clutch switch.
As I said, I maybe wrong but that’s my thoughts as to what it is.
On mine I run with the clutch switch bridged / closed all the time with the clutch switch deleted and left idle. Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #919141 29th Aug 2021 9:50pm
Bluest
That looks like someone has run an accessory wire from the dash. I have run run some extra wires to/from additional dash switches through that same bulkhead grommet. My guess is something that was fitted has been removed but the wiring remains.
I’d check if they are live or not. Also if you have any accessory switched inside (spotlights etc.) see if it becomes live when you press those. Maybe pull the dash centre panel to see if you can see the other end of them. 2007 110 TDCi Station Wagon XS
Post #919168 30th Aug 2021 7:27am
dorsetsmith
clutch switch wire green/orange------------ to fuse 13 --------black/white ---- to ecu
have look at clutch master for switch and wiring Idea
Post #919170 30th Aug 2021 7:31am
dorsetsmith
having had closer look at wires orange / white ------- orange / black
Post #919186 30th Aug 2021 8:25am
