Home > Puma (Tdci) > 2.4 Turbo to Exhaust Gasket
nickhodgson
Hi
Is there a gasket on a 2.4 Puma between the Turbo and Exhaust (the square connection). In the catalogue there is no mention of the gasket and can't find a part number elsewhere.
I do see on eBay some gasket sets being sold with what looks like a square gasket but no LR part numbers are mentioned.
Thanks
Nick
 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #918102 21st Aug 2021 11:15am
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
I was informed by island 4x4 that there is no gasket listed for this joint.
I just used some exhaust paste on mine and it doesn’t seem to leak.
Post #918128 21st Aug 2021 3:41pm
dgardel
Italy
I confirm, no gasket... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #918478 24th Aug 2021 8:29am
nickhodgson
Thanks Guys 1995 300tdi Defender 90 P/UP
Post #918557 24th Aug 2021 3:54pm
Ianh
I wonder what Lr use as the sealant ?
Ps. I also wondered what part 13 was, and saw it was “Anti-squeak grease” which made me smile Very Happy ,it’s for the turbocharger actuator rod. But then I saw the price, £51.45 a tube, at which point I fell out of my chair Neutral
Post #918573 24th Aug 2021 6:56pm
InternationalDBA
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
No gasket
I have the 2.4 engine in a 2008 Defender.
I first removed it in 2016 to change the clutch but there was no gasket.
I removed it again in 2019 to rebuild the engine.
I am currently refitting it now following a chassis change.
I saw some gaskets available online and queried this with my supplier (Brook Street Garage, Cuckfield).
They checked with one of their mechanics who has worked on several of these engines and he confirmed that these engines never had gaskets.
The ones available online may be there for owners who want to fit a gasket but they are not required.
Post #1060397 12th Feb 2025 5:50pm
IanH - Yes, that’s the grease I was on about in a tiny tube as well.
In effect it’s just high temp ceramic grease, to be honest I’m still not sure grease is ideal for that as it will gum up anyway and lead to laggy performance.
It might be fine at first, but over time gets sticky, which why I use a bit of 3 in 1 on a regular basis.
Off Topic Chillin In The Backwoods🇬🇧🇺🇸
Post #1060488 13th Feb 2025 2:58pm
