Home > Maintenance & Modifications > Caliper bolts question - getting into them!!!
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Started to change my Puma MY2013 rear discs and pads today. And whilst I wouldn't exactly say I fell at the first hurdle, I'd definitely class it as within sight of the starting line Censored
I got the pads out, bottom caliper bolt was a wee bit tight but got it off pretty easily. Then the top one. I couldn't even get my socket in the space, never mind the ratchet or breaking bar. It fouls on the bottom of the rear spring. I shifted the jack and stands and jacked up the chassis so the axle would droop and spring hopefully sag out of the way but still not enough room.
Am I doing something obviously wrong? I've only read or heard of folk having bother with bolts that are stuck or shear not with actually getting into them.
Post #917615 18th Aug 2021 8:32pm
Dinnu
Can use a ring spanner? Get the ring of another spanner into the open end side to increase leverage. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #917629 18th Aug 2021 10:11pm
MussEd
Worth a shot - thanks Dinnu!
Post #917630 18th Aug 2021 10:15pm
jst
3/8 short socket Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #917647 19th Aug 2021 7:28am
I don't recall what tools I use for this job but have never had any difficulties. Are you using 1/2" square drive socketry? If so, as jst suggests try 3/8" drive (it is rare that I ever use 1/2" drive). I seem to recall that a shallow 3/8" drive socket and slim ratchet fits straight on, and a 3/8" drive socket with the appropriate extension can pass the spring and come out behind.
Post #917652 19th Aug 2021 8:06am
donmacn
I think I also used a 350mm 3/8 breaker bar, and turned the wheel to move it slightly away from the spring. Those guys can be tight in there. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #917653 19th Aug 2021 8:09am
MussEd
I was using 1/2” hence the issue. Got a wee socket on there this morning, fitted like a glove and I’ve rounded the bloody thing off. So I’m really screwed now. Why oh why do I bother!
Post #917664 19th Aug 2021 8:47am
hank
Are you using a 6 or 12 point socket? The caliper bolts have a 12 point head. If you are using a 6 point socket then it will be driving across the points of the head and easy to slip. Try a 12 point socket which will drive on the V's of the bolt head
 > 110 XS Double Cab
Post #917674 19th Aug 2021 9:09am
donmacn
Censored . Hank is bang on about the 12 point socket.
If the worst comes to the worse, then all I would say is.... Cobalt drill bits.
I used them recently to remove a rounded cylinder head bolt on a V8. First time I'd used cobalt and was amazed at the difference. They are expensive, but worthwhile. If you started with a 3mm, then up to a 6mm, then a 9 or 10mm that would do the job.
You would only need to drill the head of the bolt enough to pull the caliper off - i.e. you wouldn't have to drill all the way down into the shank of the bolt. Once the tension is off the bolt, the rest should come out easily, though as those are threadlocked they may still put up a fight. Donald
in the past..
Post #917697 19th Aug 2021 10:09am
MussEd
Yeah I got 12 point socket after seeing a few posts. Still rounded. I’ve stuck the pads back in and taking car to a professional to get the work done. Defeat well and truly admitted! Thanks for the advice chaps. I’m just a hamfisted dolt!
Post #917710 19th Aug 2021 11:06am
donmacn
Not at all.
I have to say, whenever I do this job I always offer up a wee prayer just in case it goes wrong. The bolt rounding is precisely the thing I always hope to avoid. I think I've just been lucky so far! Donald
in the past..
Post #917714 19th Aug 2021 11:31am
donmacn wrote:
... You would only need to drill the head of the bolt enough to pull the caliper off ....
The only problem with this is you'd probably need to take the axle off the vehicle first to get access Sad
Other options might include cutting or grinding the head off so that the caliper can be removed, after this the disc can come off and the "other end" of bolt becomes accessible, or welding something to the damaged head of the bolt so that it can be gripped.
Post #917715 19th Aug 2021 11:35am
donmacn
I'm not near my car at the moment to take a sense check, but I thought, if you put the wheels on full lock that you'd get into the bolts with a drill?
I'd imagine that getting in with a grinder would be even more difficult?
This demonstrates why I always offer up my wee prayer for the damn things to turn! Donald
in the past..
Post #917718 19th Aug 2021 11:49am
Dinnu
Problem is that the OPs caliper is on the rear axle, not the front axle.
He does not say if it is a 90 or 110, but I know the 90 is more limited space wise... I do not know if there is enough space due to the fuel tank brackets. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #917723 19th Aug 2021 12:26pm
donmacn
Doh!!
My mistake. Should have read that more carefully. Donald
in the past..
Post #917724 19th Aug 2021 12:27pm
