Home > INEOS Grenadier > Double cab pickup
Page 2 of 3 <123>
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
rear door design is different between the rendering and the prototypes. looks like they just use the wagon rear door and an infill panel which is just the same as a 70series. Makes sense.
Post #917556 18th Aug 2021 2:01pm
I think I like the rendered door better.
Post #917574 18th Aug 2021 4:35pm
Is that about 6 inches added into the wheelbase and looks less than the earlier rendering?
Post #917578 18th Aug 2021 4:43pm
kenzle8a
I would put money on it being more of a tray back or modular build.
Post #917579 18th Aug 2021 4:46pm
Mike_E
agree the rendering looks much better - they may have used the bodged up wagon rear door just for the prototype and a more refined solution will (hopefully!) be available on the production models.
Post #917583 18th Aug 2021 5:11pm
Bluest
It looks like there is a trim piece missing to cover where the wheel arch used to be. I thinks it’s likely at this stage that the SW door in the pics is what will go into production. It’s probably not economic to produce 2 different doors for such a low volume vehicle. I think it looks ok. 2007 110 TDCi Station Wagon XS
Post #917585 18th Aug 2021 5:16pm
Mike_E
Post #917587 18th Aug 2021 5:42pm
Assuming it would then look like this?
It's nearly big enough to put a Rivian box in...
Post #917589 18th Aug 2021 5:50pm
More images from FB, but I don't know whether they are official or not?
Post #923980 1st Oct 2021 9:11pm
ChasingOurTrunks
It looks cool, and I like it, but that wheel placement has me concerned. I'm in for the wagon so it doesn't really matter anyway, but it's an observation I have.
The 70 series doesn't carry weight well because the tray has the majority of the load space behind the wheel, so the rear axle acts as a pivot.
Unless Ineos stretch the chassis or relocate the rear axle, they are going to have the same problem with their Dual Cab -- too much tray space behind the axle.
Granted, the suspension is a bit different on the Gren so it may compensate, but the best way to carry a load is the axle in the middle of the tray (as far as I'm aware).
Post #923991 1st Oct 2021 11:49pm
Where to put the spare in a double cab is always an issue.
I've actually got mine in a similar position as the standard factory position attached to the rear bulkhead robs too much load bed space.
Can't see properly but is the bed completely flat width ways? No protrusions for the wheel arches?
Post #923996 2nd Oct 2021 6:01am
Hweebe
Australia
This would definitely give the 70 series a run for its money here in Australia.
The benefit of auto as well would also probably kill off the pricey LC200 chop conversions.
Extended wheelbase is a big plus.
I'm up for a wagon but understand how this would have big appeal in the Ute 4x4 dual cab market in Australia.
Post #924136 3rd Oct 2021 4:00am
Looking at where the wheels are, there must be arches in the bed. Darren
Post #924166 3rd Oct 2021 7:31am
Prospector
United States
If the Grenadier pickup version is dimensionally different from the station wagon version, would separate government certifications be required (crash test comes to mind)? As I recall the station wagon Grenadier dimensions posted (several months ago) were 194 inches (493 cm) overall length and 115 inches (292 cm) wheelbase. From the concept photos shown in this thread, the Grenadier pickup’s wheelbase seems similar to that of the station wagon. Will this limit the box length of the pickup bed to 48-54 inches (122-137 cm)? A bed box any longer would result in (1) cargo center of mass (uniformly distributed load) well back of the rear axle and (2) compromised departure angle.
Just to put some perspective for pickup dimensions, I drive a 2020 Toyota Tacoma double cab TRD Off-Road with a 5-foot (153 cm) bed box. The Tacoma’s overall length is 212.3 inches (539 cm) and wheelbase is 127.4 inches (324 cm). Most “mid-sized” double cab pickups marketed in the US try to achieve a minimum 5-foot bed box.
Toyota’s flagship station wagon, Land Cruiser, measures 195 inches overall and wheelbase of 112 inches. Wheelbase and overall length of the Land Cruiser and Grenadier are dimensionally comparable. Please understand, I don’t think the Tacoma is in the same league as the Land Cruiser, but it is an easy search to use for comparison of capable off-roaders.
If the Grenadier’s frame is lengthened to accommodate a pickup double cab version, would the frame need to be structurally re-engineered? Note the Tacoma’s wheelbase is 15.4 inches (39 cm) longer (14%) than the Land Cruiser, and the overall length is 17.3 inches (44 cm) longer (9%). Hopefully, Grenadier can produce a pickup double cab version within 5% of its station wagon dimensions.
Post #925872 15th Oct 2021 8:39pm
Station Wagon is 2921mm wheelbase; double-cab pick-up truck and a seven-seat station wagon, will be 3175mm.
Post #925874 15th Oct 2021 8:44pm
Page 2 of 3 <123>
