Home > Tdi > Thermostat bleed plug |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
Hi all i wanted to swop the rubbish plastic thermostat housing bleed plug for a brass one 5 minutes of a job :rolllaugh: the housing came off easily enough but despite my best efforts i cant get the old plug out the "nut" has completely rounded off now any body any ideas to get this :censored: thing off
Thanks in advance simon WHAT COULD POSSIBLY GO WRONG My sky lantern petition http://chng.it/HJXmZC47 |
1st Apr 2018 4:47pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1849 |
I think that's a tricky one. You can cut it out, but you need to ba careful not to let the swarf into the cooling system.
If it was me I'd take the thermostat out first, then fill the housing with a rag, or paper towels, then cut it out carefully. But the main reason I thought I'd post was to say 'be careful' of the brass plug. I fitted on a while ago, and trying to get it off recently was a real pain. I think it had to be cut off too. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
1st Apr 2018 5:35pm |
Thanks for that I'll bare in mind that when I for the brass one I already have the housing off so I'll clean it out properly before refittimg WHAT COULD POSSIBLY GO WRONG
1st Apr 2018 5:50pm |
If the housing's off it's easy enough. Just be careful then that you don't cut into the threads in the housing. Donald
1st Apr 2018 5:57pm |
In the end I just bought a new housing and put a brass plug in it was worth it as it makes bleeding the cooling system a doddle (very important with thec300 tdi) best of luck simon WHAT COULD POSSIBLY GO WRONG
17th Aug 2021 9:09pm |
And just to add to that, the housing "shouldn't" be hard to get off - but it's possible.
From memory it's the two bottom nuts that are the most awkward to access, but the top bolts go into the head and could gunk up. And, having slagged off the brass plugs in an earlier post, the current one has been in for a few years and is behaving very well. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
17th Aug 2021 9:16pm |
