Home > Maintenance & Modifications > Startech Steering Wheel |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
I have a ST wheel on the standard boss and yes the indicator is slightly further away but I no longer notice it. It is not an issue
16th Aug 2021 2:01pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2293 |
Hello OwenB and welcome
My 90 came with a Startech Steering Wheel, which is (IMO) still the best alternative, although more than a bit Pric£y Job No. 1 (for me) was to fit a Quick Release Steering Wheel Boss, I went for Snap Off, but look at Optimill + the Lockable Cap as your at this stage. Now fitted I would never not have this security feature, seconds to use, and as a layer in your overall protection, a good one. Dimensionally I ended up here... all good and very close to the original set up, full Instrument Stalk use and Dial Visibility but with a better feeling Steering Wheel... It also improves the degree of comfort now using a small wheel when seated so close to the door / window, the Power Steering easily copes with the reduced mechanical advantage of fitting a smaller wheel and the whole experience is just improved, each to there own on this Mod' but I would never go back Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
16th Aug 2021 4:00pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7894 |
Highly recommend the startech, best wheel IMO. I've got a quick release boss so can't comment on the question. Another big expense but I would put the Optimill quick release boss on your shopping list.
PS welcome to D2N James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
16th Aug 2021 4:25pm |
OwenB Member Since: 16 Aug 2021 Location: Suffolk Posts: 4 |
Thanks very much |
16th Aug 2021 4:30pm |
This is brill, thanks very much. Just measured my standard wheel and that 50mm to the stalks. So not so different at all. I wonder if the Optimill QR is deeper than the standard Startech one. |
16th Aug 2021 4:32pm |
Thanks very much for this. It’s definitely the only choice for me as I want to keep it looking fairly OE. I am also looking at that Optimill QR, but £££££££ on top of a ££££££ wheel!😂 |
16th Aug 2021 4:33pm |
