Home > Puma (Tdci) > Advice on shocks
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
Advice on shocks
I need to replace the shocks on my 110 however am looking to get the best value shocks for my money. I have been looking at terrafirma pro sport or if really genuine worth the investment (not just for the looks) OME. Any thoughts as to what other people would recommend would be great to hear. Mainly for road use, standard springs and occasional offroad use.
many thanks
Post #916946 14th Aug 2021 3:50pm
Bluest
OME shocks are good. I have them in the rear at present and will be putting them on the front when the time comes. I don’t get the impression terrafirma are particularly high quality, prone to breaking. 2007 110 TDCi Station Wagon XS
Post #916951 14th Aug 2021 4:17pm
Mdm
OME are great if expensive. give gywn lewis a call on them and he can advise what will work fo you.
avoid the cheap end of the market. terrafirma are ok but they rust fast. they last well though
Bearmach have 3 yr warranty and you can upgrade from oil to gas which i think are better all round
Post #916964 14th Aug 2021 4:53pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
The best investment would be a set of std hight Fox 2.0
Post #916999 14th Aug 2021 7:38pm
discomog
Another thumbs up for Fox Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #917004 14th Aug 2021 8:29pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I have OME and they are very good, also got the from GL too.
Post #917011 14th Aug 2021 9:48pm
Sam smith
ok thank you for all your replies, i think ome may be slightly out of my budget if i think about it realistically. So if there are any more sort of mid range shocks that you could recommend that would be great thank you (similar prices to terrafirma would be what i am looking to spend)
cheers
Post #917048 15th Aug 2021 11:10am
Bluest
If you look on Euro Car Parts, they sell Sachs (choice of gas charged and normal), Monroe (who make OME’s shocks) and KYB. They are all proper reputable manufacturers and should be decent and ECP almost always have a big discount code on the go. Need to keep in perspective this is a Defender after all. 2007 110 TDCi Station Wagon XS
Post #917055 15th Aug 2021 11:35am
markb110
Sam
Seven years ago when i gave Frogs Island 4x4 my TD5 90 to learn how to install a KAM rear locker with limited slip they gave me a set of pro-type plus 5 inch adjustable shocks to test. These are pin to pin fittings.
i only replaced those last month.
You only need the standard or plus 2 inch depending on your use (normal fittings)
The breakages that you sometimes hear about at the rear upper fixing because the bolt has been over tightened and thus not allowing the shock to rotate as the axle drops through an arc (the wheel does not go straight down).
To check this, do the top fitting on the rear up first, then swing it through an arc, if its too stiff or wont move then it is too tight, then connect the lower shock mount.
when testing the adjustable shocks i used setting 1 for pure off-road, 2 for general driving around for comfort, 3 for fast road work (very supportive up to 90 mph, no body roll when over taking) and 4 did not suit the weight of the 90 nor the mud terrains i run (i value my fillings and spine)
I have now fitted OME as i have always wanted to try them.
hope this information helps you.
Thumbs Up
Post #917092 15th Aug 2021 5:37pm
stephan123
+1 for Fox coupled with standard springs
Post #917105 15th Aug 2021 6:21pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
OME get the Thumbs Up from me, both front and rear done and well worth it
Post #917106 15th Aug 2021 6:35pm
MartinK
Koni Heavy Track Raid for me. Been on about 8 years. can't fault them Thumbs Up
About £180 per axle Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #917184 16th Aug 2021 7:51am
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Very happy with my set up which is primarily for road use:
Bilstein U-B6 Performance Damper Kit.
H&R progressive  - 1" lowering spring kit.
H&R anti-roll bars.
Superpro poly bushes.
No body roll, no bounce on a country roads. incredibly stable at speed (+90 mph) Thumbs Up
I understand my set up is commonly used by Twisted and Urban. I've not tried Fox but hear good things also.
Post #917230 16th Aug 2021 11:16am
Co1
^^^ 90mph?!! What have you got under the bonnet?!
Post #917293 16th Aug 2021 5:33pm
ChrisCSL
Running a 2.2 puma with Alive ECU Remap to approx 175hp / 500NM with Black Series Intercooler, Air Filter and Miltek Stainless Steel Exhaust Thumbs Up
Post #917414 17th Aug 2021 1:45pm
