Home > Puma (Tdci) > Ford Transit Detents
Donald.e
Jumped into my 110 went to start it, bloody in gear without depressing clutch, shouldn’t have been a problem but Aye it was now stuck in 1st gear couldn’t get it out.
Anyway found the answer here on Defender2, Remove Detent, insert small screw driver flick it forward, Done this Bingo Sorted.
The Detent in question was the newer flush type so, thought no problem there are an couple of Independent LR specialist in the area I’ll get a new one, and indeed worst case scenario there is the Main Dealer, anyway failed miserably could supply could only supply a full kit at £85 plus VAT, but was on back order with no date of supply.
So decided to try The Ford dealer to see if they could supply from the Transit with the MT82 Gearbox, after a bit of searching through their parts software identifying the part, they had one Detent in stock at £12.41 including VAT
This Detent looked like the older Mushroom Head type.
This got me going and been going for a couple of days now.
My Question is, any issues with these, or should I look at changing it when I get the kit
Post #915525 4th Aug 2021 10:20pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Aren't the older style larger in diameter? Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #916979 14th Aug 2021 6:25pm
Donald.e
No, it does fit, but has the dome head as opposed to flush
Post #917039 15th Aug 2021 10:27am
Gloucesternige
If I'd known that I would have bought those when I rebuilt my MT82. So much better to have a re useable option. Nige
Post #917040 15th Aug 2021 10:57am
