![]() | Home > Puma (Tdci) > Ashcroft 4-pin vs ATB. Am I being daft? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
everything you need to know is here
https://www.defender2.net/forum/topic13545...hcroft+atb DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Fit the ATB’s
![]() Yes. Fit and forget |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
ATBs every time. The cost difference make it a no-brainer. I've got them in one of my 110s and seriously considering doing the other one as well.
You'll see some comments and Youtube vids saying they don't work. I've no idea how to reconcile that with my experience which is that I don't think I have spun a wheel, and I certainly haven't been stuck, since fitting them. I guess left foot braking works but I have never needed to. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
I have an Ashcroft ATB in the back of my 110 and wish I had one in the front. Although the rear diff has (since the upgrade) always whined a bit under partial load and I keep not getting round to fixing it.
It's perfectly possible to break a 4 pin front diff as I found to my cost last year. Took a bad line up a track and stopped going forwards. No wheelspin, aggressive driving, shock loadings or oversized tyres. Reversed, took a more sensible line and by the time I got to the top the front diff was making some very interesting crunching noises every ~4 rotations of the input shaft. |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
Brilliant - thanks all. Right, no brainer it is. As LR90XS2011 says, I think all the technical queries are answered by the thread linked above Better get saving!
Yes the youtube videos are a bit odd, there's a couple of guys on there in Discoveries that show them as being basically completely inoperative in a cross axle even where they're flashing the brake lights, which is weird. Then another with a P38 that shows exactly what you'd expect - cross axled, dabs brakes and it (granted, quite weakly and no where near as confidently as T/C or a locker) crawls over the obstacle - the P38 vid seems to show the diff working and is so modified I suspect T/C has been disabled. The only remaining debate I have is whether to have them fitted by a specialist like Ashcrofts or Xcess4x4 or whether to just give the diffs to the (very good) LR garage that is doing the chassis for me (they do rebuild Series transmissions and the like so they're not just chassis swap people). Not sure if its a highly specialised install or not. Having them do it is easier from a logistics perspective (collecting the diffs, sending them off etc) |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Have them front & rear built up by Ashcroft’s for the additional cost & knowing these guys could build these up blind folded it’s a no brained in my eyes!
Thanks - came to the same conclusion. Have called ashcrofts and reserved a set and will be sending the diffs down to them - very exciting.
Anybody who can build a diff or fit a new centre can build in an Ashcroft ATB. It's not hard to build it better than factory, I found when I stripped mine that the crownwheel bolts fitted by Land Rover had no loctite on them! But if at all unsure get an expert to do it. ---
