![]() | Home > Puma (Tdci) > Loss of power for no apparent reason |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17720 ![]() ![]() ![]() |
Classic symptoms of a faulty VCV (Volume Control Valve) on the fuel pump. Not expensive to change, causes all sorts of weird running issues when faulty and doesn't tend to generate DTCs.
I strongly recommend that you change it, even if only to rule it out. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Sounds like a VCV issue.
https://www.defender2.net/forum/topic25121.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thea Member Since: 09 Aug 2021 Location: cassis Posts: 2 ![]() ![]() ![]() |
ok thanks. That will be the next thing to try. fingers crossed it solves the problem. Thanks so much.
