Home > In Car Electronics > FM aerial
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
FM aerial
Typical of most defenders, mine has the classic slide down aerial on the front wing. I keep it down most of the time because it looks crap! Pretty much get radio 1 fine, but most other stations are poor.
What do you lot do? Is there a suitable alternative to the daft defender FM aerial? Or am I in the minority and everyone else loves it?! I’ve got the standard Alpine head unit
Post #915090 1st Aug 2021 11:25pm
Bluest
I can’t say I’ve ever given the appearance of the aerial a 2nd thought. I do lower it when off road to stop it getting snapped off by trees though. Nakatanenga do an alternative style one. 4x4 Overlander sell it. 2007 110 TDCi Station Wagon XS
Post #915113 2nd Aug 2021 8:49am
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I would thoroughly recommend the Nakatanenga aerial.
Top tip, remove the panel on the top of the wing when you come to switch it over. 2011 CSW XS 90
Post #915123 2nd Aug 2021 9:55am
I have the Nakatanega one, no complaints from me. WeWillWin🇬🇧🇺🇸
Post #915138 2nd Aug 2021 12:26pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
I like the crappy standard aerial.
Set it to the height of the vehicle. Hey it checks the height when going under height restriction barriers Thumbs Up
Post #915198 2nd Aug 2021 8:04pm
pilsburypie
I shall have a look at the naka-jobbie.
Also like your height restriction warning too!
Post #915229 2nd Aug 2021 10:15pm
MichaelE
When I had to chop my old aerial off the wing , first I couldn't find a suitable replacement that wasn't a stupid price, and second I didn't want the hassle of feeding the cable through. I had just fitted a heated screen and didn't want reception problems with a stick on aerial. As I already had the front roof lining off, I opted for a sharkfin type. Because the rear roof lining is a pig to remove and refit, I fitted it at the front and it looks ok. It's slightly offset from centre because there's a roof rib there but it's only an inch. It works well, FM and DAB. But if I were to do it again, I'd put it at the back where standard cars have them.
Post #915260 3rd Aug 2021 8:51am
pilsburypie
The shark fin is the neater option. But has to have a hole cut in the roof.
I’m going to live with my original aerial for a bit, see if I can get used to it then consider the options.
Thanks for all your thoughts.
Post #915267 3rd Aug 2021 9:09am
