![]() | Home > Maintenance & Modifications > Fiting MSS 'Fully Loaded’ Metal Cubby Box |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
Hi all
had a task to do today on my partners' 110 which was to fit the MSS cubby box. https://www.mobilestoragesystems.net/produ...7649550151 ![]() Click image to enlarge The Cubby was about the same size as the original one but with a lovely soft arm rest on top (The supports are under the original one so it looks slightly taller.... ) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The task stated with the removal of the subwoofer from the back of the cubbybox, and then to under the 4 bolts holding it to the floor. ![]() Click image to enlarge next was to fit the supporting fittings to the floor - the job was simple and did not require any drilling. ![]() Click image to enlarge then bolt the cubby to the fittings and attach the various bits like the cup holders and fit and wire in the CB radio into the radio section and add the USBs and power fittings. The fully loaded cubby comes with x2 power sockets on the back which I wont be using as this area will be covered by the Subwoofer. ![]() Click image to enlarge I am going to fit the subwoofer to the the back of the cubby at a later stage when I have an extension cable to save me drilling a large hole in the box. simples ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
