Home > Puma (Tdci) > 2.4 Turbo Replacement |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3328 |
Yep, good luck! Worth fitting an uprated gasket while you're at it. https://www.4x4overlander.com/product/naka...-gasket-2/ WARNING. This post may contain sarcasm. |
8th Apr 2021 7:28pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
You will have to remove the studs to get it out, which is a bloody stupid bit of design, so possibly get spare studs.
8th Apr 2021 7:43pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Yup, so I've got the Naka gasket already. I've got oil feed, all bolts, studs and gaskets.
With the turbo included, all from LRDirect, it coming in at £601 inc VAT. So a good £700 cheaper than getting the cheapest garage to do it. I wonder if I'll regret that when I'm halfway through the job with 3 rounded studs. I think I'll start soaking those nuts in penetrating fluid tonight! |
8th Apr 2021 8:19pm |
It’s a really easy but annoying job. You’ve just got to remove stuff that is in the way as it wasn’t designed for the vehicle.
8th Apr 2021 9:04pm |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 78 |
Just replacing mine too, I managed to do it without removing the exhaust studs.
Is it really critical to replace the oil feed pipe ? |
30th Jul 2021 8:21pm |
