Home > Puma (Tdci) > MY15 2.2 Puma 90 - Damaged Speedo Sensor cable connector |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 622 |
It is a standard 3 way Econoseal exactly the same as rear stop/tail lights.
https://www.vehiclewiringproducts.co.uk/p-...arch=01252 Or ebay |
26th Jul 2021 3:24pm |
Gleo Member Since: 01 Mar 2016 Location: Mayo Posts: 43 |
Hi Oldowner
Following your advice many thanks, I ordered the 3 way Econoseal from VehicleWiringProducts Ltd, fitted it this morning and still no speed going back to the dashboard. Any ideas which relay is used on the 2.2 Puma for the Speedo Sensor, as that's my next check point, but I am not sure where its located, as its not specifically marked on the fuse board panels? Thanks again |
30th Jul 2021 11:19am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
There‘s no relay involved. Ignition live (white green) coming from fuse 11 (10A), black is ground, black-red is signal to instrument cluster which calculates and displays speed.
30th Jul 2021 11:27am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
What if you connect to the obd, are you able to read the road speed?
According to electrical manual there is a 10A fuse in Junctio box-Central (P101). I do not know if that is beneath the driver seat or below the steering.[/img] 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
30th Jul 2021 11:32am |
^^ I see it as Fuse 12. But maybe different manuals have different numbers. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
30th Jul 2021 11:33am |
OK, so no relay involved then, and I've checked the standard fuses and they seem to be fine.
The rest of the dashboard, rev counter, Mileage,Trip etc is fine, - maybe the pulse cable got damaged or stretched further up within the loom when it snagged. Looks like I may have to cut the 3 speedo cables further up, and then re-splice in 3 x fresh cables. I onlyassumed it was going to a relay after looking at a diagram within this thread here: https://www.defender2.net/forum/topic70342.html?highlight=c0195 |
30th Jul 2021 11:39am |
That diagram shows how to use the ignition live in the speed transducer cable to switch a separate relay; not that a relay is part of the original circuit. Darren
30th Jul 2021 11:51am |
For MY 2015 it should be F11 under the driver's (i.e. right) seat. It's labelled with an instrument cluster icon on the sticker under the lid. This fuse box is called BJB battery junction box or main fuse box. |
30th Jul 2021 12:42pm |
Baytown Member Since: 30 Jan 2016 Location: Cairns Australia Posts: 83 |
Hi Gleo;
It’s been a while since you last mentioned this issue. Have you sorted it and if so, what was the problem? I’ve a similar issue after removing a wire from an unrelated circuit, lost my Speedo and odometer on my Puma 110. I expect I’ve stretched wiring as well as I’ve checked the binnacle, resoldered joints, rewired the connectors have signal at the OBD port, so loss of signal between OBD and binnacle. I’m really interested in what your outcome and fix is. Thanks for any help with this. Ken
1st Nov 2021 11:38am |
Click image to enlarge Click image to enlarge Click image to enlarge Hi Yes, I got a new Ecoseal from: https://www.vehiclewiringproducts.co.uk/p-...arch=01252 as recommend by Oldowner. I didn't have an Ecoseal crimper but was able to do it with a standard crimps, just need to ensure the cables go in the correct way, it's easy to look at the plug upside down and mix up pin 1 and 3 or visa-versa. I removed the speedo sensor to do a 'dry' test (before pushing the crimped ends into the plug), spun it by hand to ensure the revs and speed were changing on the dash, but if you do do this be very careful not to short the bare crimps off one another or you'll blow fuses or damage the speed sensor. Click image to enlarge Click image to enlarge |
1st Nov 2021 1:06pm |
Thank you mate, and I’m glad you managed to fix your issue. Well done!
1st Nov 2021 9:01pm |
