Home > Maintenance & Modifications > Is a yearly service really needed
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
In the past 12 months my 2.4 puma only did 3000km. Its now due for its 10th yearly service. There is only 82 000km on the clock. Can I skip this service on account of the low kms done in the last 12months or is the yearly filter and oil changes critical?
Post #914463 28th Jul 2021 3:42pm
Bluest
A few things that come tom my mind.
If you want an unblemished service record, then you'll have to get it done as it is needed according to the schedule. If you do lots of short journeys in that 3000km I would still do it as that is worst type of driving for oil. Oil and a filter is fairly cheap, so is it even worth skipping? What else is due this service? Does it need any of the transmission fluids changing or the coolant?
If none of the above are an issue, then my personal view is there is no real technical reason why you couldn't skip a year with such low mileage
If you are really concerned you could do an oil sample test which will tell you if the oil is still fit for purpose and doing its job. 2007 110 TDCi Station Wagon XS
Post #914477 28th Jul 2021 4:57pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Same dilemma myself, under 2500 miles since last mot which was redone today, iess since last service which was in November 20, transmission oils were done same time Question
Dont want to be throwing money away, but its peace of mind I guess Whistle
Post #914479 28th Jul 2021 5:10pm
LR90XS2011
I do mine religiously even though I do low mileages.
However logic would say that the service schedule is designed for a worst case senario, so if you know it is used gently, warmed up properly, does longer journeys at low load and dosnt tow big massive trailers, then it would not be unreasonable to expect to be able to extend the annual criteria, and if for instance you pushed it out to say 18 months then your servicing costs would be significantly reduced.
My reason for doing it annually despite the low mileage used to be the fact if something did fail that was service related I would kick myself and self servicing is a good chance to spot other emerging issues.
Since buying the caravan it works somewhat harder than it used to so I now justify it to myself on that basis.
If I was working to a budget, I wouild prefer to use high quality components and oil, as I do now and extend the frequency rather than buy cheap components and oil and stick to the schedule if that makes sense. DEFENDER 90 TDCI XS,
Post #914481 28th Jul 2021 5:18pm
Mdm
the lower the mileage the more need for regular oil changes.
i know many cars can do 2yrs with little to no maintenance but that doent mean they are roadworthy or its good for the running gear.
it just means that the 3 yr warranty period is as cheap as possible for 1st owner
Post #914484 28th Jul 2021 5:31pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Does not the oil lose its viscosity with time and as mentioned short journeys do vehicles no favours.
If i was buying the defender if service schedule was not maintained it may make me think that the person has also neglected other aspects of the vehicle also so may feel its not for me.
However, if you keep the vehicle yourself this will not be a problem.
Post #914486 28th Jul 2021 5:40pm
kenzle8a
I don’t just base it on mileage, i will do a yearly one regardless, or every 10k if that is sooner than a year on my td5. My other car is done every before the summer and winter as i run different weights of oil.
Post #914498 28th Jul 2021 7:03pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Not a good idea, personally I wouldn’t skip a oil change.
Post #914517 28th Jul 2021 8:22pm
I get mine done every other year, I don’t do big milage but I do change the air filter each year and other basic maintenance stuff $W33T $0U7H3RN $UG4R
Post #914539 28th Jul 2021 9:44pm
jst
You can skip the service but I wouldn't skip the engine oil and filter change. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #914628 29th Jul 2021 4:13pm
A low annual mileage and only short runs to my mind makes the oil change even more important. If you do a high mileage and only long runs, your oil is likely to be in much better condition after 12 months than that of a low-use vehicle.
Post #914631 29th Jul 2021 4:29pm
Mike c
Always been at least once a year for engine and fuel/filters for me since owning a Land Rover, however this has been the lowest mileage I have ever covered over a year, hence understanding the op dilemma.
I will still get the basic engine service done I think and have already ordered the oil, filter kit next, its peace of mind and will feel better Thumbs Up
Post #914632 29th Jul 2021 4:35pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Re: Is a yearly service really needed
I change my oil / filter every 3K miles, regardless of time. Good practice IMHO. Also, every year, around the MOT time, I change the diffs and transfer box fluids too.
Post #914912 31st Jul 2021 3:57pm
Marius
OK so I think I'm just gonna change the oil and air/fuel/diesel filter myself rather than taking it in to the shop. Its just a filter and engine oil service.
Post #914914 31st Jul 2021 4:09pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Pretty much what I do. Rgds.
Chris
Post #914964 31st Jul 2021 9:16pm
