Home > My Defender > My Keswick Green XS USW
Page 20 of 20 <123 ... 181920
Steve R
2013 Defender 110 Puma 2.2 USW Keswick Green
Brilliant, thanks for sharing that thread. Thumbs Up
It’s addictive isn’t it - so many mods possible (and cheaper than the 1:1 version when you break things)!
Post #907971 15th Jun 2021 5:47pm
Gasket
Beautiful 110 Steve and some great photos.
Re: the rims before and after, how do the wheel studs compare in terms of length/stick-through? I'm guessing a couple of threads short of filling the nuts with the wolf rims, but would be curious to see if the ANR classics fare are any better in that regard (i.e. do they have a thinner disc?).
Post #913633 22nd Jul 2021 8:27pm
JOW240725
I 'needed' to fit extended studs with my ANR's the same as for Wolf rims. I say needed, my garage man wasnt happy and neither was I. I was always taught you need a minimum 2 full threads through the nut, so for peace of mind just fitted extended studs. James
Instagram @suffolk_rovers
Post #913662 22nd Jul 2021 10:21pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Should never run with wheel nuts that have threads short when torqued up! Big Cry Rgds.
Chris
Post #913664 22nd Jul 2021 10:22pm
Land Rover sold them like that from the factory (both civilian and MoD vehicles) so the risk was clearly acceptable to them. Darren
Post #913666 22nd Jul 2021 10:27pm
Pacha
I am not surprised in the slightest - it's still not a good practice!. Big Cry Rgds.
Chris
Post #913668 22nd Jul 2021 10:31pm
I have them on mine from the factory; but then you think of the same engineers' response to poorly welded axles, and probably a few other issues...
Post #913670 22nd Jul 2021 10:41pm
But this isn't a response to a problem Confused It also ignores the fact that this arrangement came with the development of the Wolf vehicles and pre-dates the more obvious penny pinching of the Puma era by around ten years, so it's difficult to draw a line between it and later questionable engineering decisions.
Unless somebody knows differently, I've never heard of an issue arising from the factory arrangement of studs and Wolf wheels and they must have sold thousands of vehicles with that configuration. Darren
Post #913687 23rd Jul 2021 6:58am
Yes, I agree not a response to a problem, but perhaps a further example of the mindset that leads them to conclude "the risk was clearly acceptable to them."
There's always going to be debate over value engineering versus plain cost cutting.
Post #913697 23rd Jul 2021 8:14am
I think that's a tenuous link at best, I'm afraid. Darren
Post #913707 23rd Jul 2021 9:10am
Yes, as I said "there's always going to be debate over value engineering versus plain cost cutting."
Post #913726 23rd Jul 2021 9:41am
Co1
For what it’s worth, the premise of two threads showing though is based on a standard nut diameter to threaded length ratio. The wolf wheel nuts have a longer threaded area and even with the stud fitting slightly below the height of the nut there is more than enough thread engaged to get the necessary torque without stripping anything.
Post #913789 23rd Jul 2021 3:37pm
Pacha
Thanks for the clarification Col - makes a bit more sense now. Rgds.
Chris
Post #913790 23rd Jul 2021 3:46pm
Co1
Don’t quote me on it, but general rule of thumb is that the length of the threads should be at least equal to the diameter.
Post #913811 23rd Jul 2021 6:39pm
22900013A
Looking at your photos Steve I need to find a way to get my set of 569203 rims onto my 110. Any ideas? 🤔 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #918883 27th Aug 2021 5:47pm
