Home > Td5 > Safari Snorkel
DevonJas
United Kingdom 2005 Defender 90 Td5 CSW Buckingham Blue
Safari Snorkel
I'm trying to fit a second hand Safari Snorkel to the TD5 and need a template for the 3 screw holes required in the wing. Also, i believe there is some type of foam gasket/seal that goes between the snorkel and the wing. Does anyone have an idea where i could purchase these or will sealant be good enough in place of the foam? is there a .pdf of the template anywhere? Havce done a search but not coming up with much. Thanks
Post #913229 20th Jul 2021 1:08pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Does it not use the same holes as the side intake? And yes there is supposed to be a thin foam gasket around the intake. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #913269 20th Jul 2021 5:50pm
markb110
You can buy a sheet of adhesive back neoprene off of eBay and make your own. They are available in many different thicknesses.
Post #913291 20th Jul 2021 7:39pm
DevonJas
Thanks for the reply, any idea what thickness would be best? What do the Safari company use?
Post #913394 21st Jul 2021 10:56am
markb110
My current roll is 3mm thick.
Surprisingly useful stuff to have in the garage…
Post #913403 21st Jul 2021 11:27am
kenzle8a
I wouldn't fit a safari one, I removed mine from my TD5 as it kept filling up with water as the neoprene seal failed.
Post #913410 21st Jul 2021 12:05pm
landy andy
I just bond snork to wing with tiger seal. It won’t fail, and the neoprene traps all the crap and trashes your paint anyway. At least I know mine is sealed.
Post #913436 21st Jul 2021 1:37pm
