Home > Maintenance & Modifications > Puma brakes lack bite |
NeedForTweed Member Since: 02 Mar 2021 Location: Cumbria Posts: 10 |
A few things I’d check:
Could be a slight leak somewhere when under pressure (bleed nipple for example). Is the fluid level constant in the reservoir or is it falling with use? Is it fresh fluid or is it from an old, previously opened bottle? Brake fluid absorbs water from the air over time and this reduces its performance (you probably know this given the work you’ve already done!). I try to use a newly opened bottle every time if I can. Could certainly be a fault with the servo itself. I’ve had them fail in a number of ways in other cars over the years. Once where the brakes were sticking on as the under bonnet temperature increased, and once where the servo assistance gradually fell away over several weeks until it was bum off seat time to affect a hard stop. Good luck sorting it! |
19th Jul 2021 10:26pm |
mangobay Member Since: 11 Aug 2020 Location: Chepstow Posts: 26 |
Thanks very much for taking the time to write - all good thoughts.
Ive decided to give it to an expert to look at, so hope to hear back later this week, my bet is on a master cylinder or servo (vacuum pump) issue, but lets see. thanks again. |
20th Jul 2021 6:47am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1790 |
check wheel bearing play as well
20th Jul 2021 11:30am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2304 |
Recently my servo vacuum pipe split and as a result left me with non-servo assisted brakes. All I will say is that you will know if this is the issue as you need to stamp on the pedal ultra hard to get any brake whatsoever!
Pull the vacuum pipe fitting from the servo then start the engine... Put your thumb over the pipe fitting, you should feel a strong vacuum. Perhaps the servo has a slight leak? You bought my front calipers to refurb after I fitted new calipers all round... Got to be honest that whilst my brakes are now better, they are by no means amazing even with new wheel bearings, disks, pads, calipers (with stainless pistons), brake lines, vacuum pipe... I put it down to the sheer mass of the vehicle > 110 XS Double Cab |
20th Jul 2021 12:17pm |
Exactly what Hank says, I did the same, everything new, swapped to Zeus pistons and still not great feel - but stand on the peddle and I can lock the wheels when stopping so all is working ok. |
20th Jul 2021 12:31pm |
Same. If I stamp on them the ABS quickly comes into play so I'm satisfied they're working to an acceptable standard, plus they performed well in the MOT, but they just don't feel as responsive as four pots I had on a previous track car... For obvious reasons I suppose > 110 XS Double Cab
20th Jul 2021 1:09pm |
Thanks guys much appreciated.
Im not expecting miracles with the new kit but I know its not working as it should (and I cannot get the ABS/lock up to happen however hard I stamp currently). Early diagnosis from my local guy is that vacuum pump isnt supporting the servo in th way it should so hopefully that will resolve it. I will ocnfirmon here for future reference. @Hank, your calipers cleaned up great by the way - they look amazing even if the car isnt currently stopping properly ! |
20th Jul 2021 1:17pm |
I’m case useful for future reference, we ended up changing the both the servo and the master cylinder in the end. Spent more than I wanted to but the result was worth it. I now have awesome brakes! Thanks all for the input.
23rd Jul 2021 6:03pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Mmmm, might have to go the same way then. Was hoping you, so I would have a cheaper solution. No happy with my brakes, even though I’ve changed most things.
Where did you get the parts from and what was the cost? |
23rd Jul 2021 8:08pm |
