Home > Puma (Tdci) > Leaking clutch fluid
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
2.4 TDCi with 97000 on the clock. Clutch replaced about 18 months ago, so less than 8000 mile on it. I find that I'm having to top up the clutch fluid reservoir with about 20ml of fluid every fortnight. Everything is fine until there is too much freeplay in the pedal movement, and it sometimes sticks on the return. Top up the fluid and its all fine for a few weeks.
There's no sign of any fluid leaking when its' parked, so any suggestions as to what might be the issue?
Post #912935 18th Jul 2021 3:45pm
LR90XS2011
if its the master cylinder you generally get fluid in the front foot well. DEFENDER 90 TDCI XS,
Post #912942 18th Jul 2021 4:47pm
hank
Get underneath the vehicle, is there moisture/evidence of fluid coming out the bottom of the gearbox bell housing? > 110 XS Double Cab
Post #912943 18th Jul 2021 4:48pm
Dinnu
Unless it is going under the carpet!! In that case, keep in mind that dot4 will eat the paint. No paint = rust.
If the slave is leaking, then it is a box out on a tdci.
I still do not understand why clutch hydraulic is specified as dot4. I hope that neither the master nor the slave reach 100dC or so. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #912956 18th Jul 2021 6:25pm
90 Dreamer
It simply most common these days, can't recall the last time I saw dot3......
Post #912961 18th Jul 2021 6:38pm
Dinnu
Indeed, makes more sense to use dot4 than dot3... but both eat paint, in case there is a leak of course.
Hence for my restoration I went for dot5 (silicone based and not to confuse with dot5.1). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #912964 18th Jul 2021 7:10pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Sorry to thread jack, but while we are on the subject: I’m going to replace my perfectly heathy standard clutch master cylinder with a lof power master this week
What’s the best way to drain enough fluid that I don’t make a huge mess in the engine bay, yet also not introduce too much air as to make bleeding of the new master difficult?
ProTips appreciated in advance 🙏🏼 Roaming around 🇳🇴🇨🇭
Post #912968 18th Jul 2021 7:37pm
Dinnu
I think better to drain the fluid from the bleed nipple. Even if there is a small amount of air in the system, you will need to bleed it completely. The positive thing is that you have new fluid all the way. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #913059 19th Jul 2021 11:57am
