Home > Puma (Tdci) > Door Leak
Leathers
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Galway Green
Door Leak
So I’ve replaced my water shedders in every door, and made sure they are very well sealed by adding additional sealant. This was part of an attack on leaks, which has been fairly successful. However….having just washed my 2008 110 CSW I have discovered small door leaks that look like there coming from behind the door card. Before I get the card off to start chasing can anyone suggest some common faults/solutions?
Post #912781 17th Jul 2021 12:28pm
Balvaig
Have you checked that the door drain holes are clear?
Post #912784 17th Jul 2021 12:40pm
Leathers
Can’t remember if I checked them when I did the water shedders last year, but possibly not….will start there. Thanks!
Post #912785 17th Jul 2021 12:54pm
Oldowner
The door drain holes are substantial on a Puma, unlikely to block.
Seal each side of the outer window seal into the corner and run the sealant up the curve of the door skin slightly, that cures most door leaks
Post #912808 17th Jul 2021 4:16pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
I changed my door seals on my Puma (now gone) 1st lot was after market ones as they were cheap but found they did not work then after watching Youtube the Britannia guys video but I should have watched before as he demonstrated the proper Land rover part against the one I bought and when I fitted the LR one no leaks just incase you have bought an after market one
Post #912819 17th Jul 2021 5:18pm
Leathers
Useful, thanks guys. What have you used to glue the outside window seals on?
Post #913289 20th Jul 2021 7:39pm
I solved this problem on mine by using some heavy plastic sheet (the stuff used for damp proof membranes in concrete) to make conventional water shedders which direct the water to the drain holes, to supplement the strange LR ones that direct the water inside the vehicle. It has made a massive difference.
Post #913306 20th Jul 2021 9:48pm
Co1
Funny you should say that blackwolf as I was looking at them last weekend scratching my head about the fact that they direct it away from the door by then back into the vehicle!
Post #913330 21st Jul 2021 5:11am
You do have to wonder why someone would take a door which has some generally excellent drain holes along the bottom, which exit on the outside of the door seal, but then fit an over-engineered water shedder which does a brilliant job of deflecting the water away from the drain holes and down between the inner face of the door and the door card, whence it then exits inside the door seal and onto the floor.
It is hard to explain this without using the word "moron".
Post #913372 21st Jul 2021 9:01am
Co1
Rolling with laughter
Post #913466 21st Jul 2021 5:09pm
markb110
Classic...
Reminds me of the drain holes in the rear crossmember that then gets covered over by the mud flaps on the 90.
Why the original designers never thought to make it with a matching holes we can only assume the bean counters decided that it would not be an issue for the original owner.....
I drilled my own holes
If you have a 90 with mud flaps its worth doing.
Post #913484 21st Jul 2021 7:05pm
Co1
Forgot about that. Another classic!
Post #913486 21st Jul 2021 7:14pm
