![]() | Home > Maintenance & Modifications > Fiting Tree Sliders |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2119 ![]() ![]() ![]() |
Hi all
I have just purchased a set of Safari Equip tree sliders to fit to the sides of our 2012 110 ready for its long overland trips which we are planning to undertake in the next couple of years. Poppy has XS long side steps and checker plating on the sills - so would need to remove these first .. (I am planning to fit the 56ltr water tank some time in the future as well but not jut yet) Safari Equip dont send fitting instructions out for the job and I have read a few posts here to see how best this can be undertaken .... Any advice? tips? things to watch for ?? ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Yikes !
how did I miss your thread when I dd a search !!! - I paid myself in finding the info on here with out asking but some how missed the whole thread you posted ! Many thanks Blust !! Me thinks that I am going to need some bigger tools to do this as my micky mouse ones may need some help ! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4247 ![]() ![]() ![]() |
It’d be worth trying them up to the car first, as others report less trouble that I had. 2007 110 TDCi Station Wagon XS
Bluest -
many thanks for your in-depth instruction and the the insights to the issues you had... ![]() Fitted my sliders today and was pleasantly surprised that everything lined up and the only issues I has was bolt alinement due to my drilling accuracy... I only needed one spacer on the centre outrigger for each side and had a slight problem loosening the bolt to attach the front end of the slider to the chassis bulkhead bolt, but managed to get there in the end. I needed no extra parts and managed to have a good fit with no need to trim the wheel arches. ![]() ![]() Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Excellent, glad it went smoothly for you. They look good
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
That looks very tidy and has inspired me to fit mine that I’ve had knocking around for a couple of years now!
This is what I have: ![]() Click image to enlarge Typically I have zero instructions and no fitting kit so would anyone happen to know what I might need as I couldn’t find anything when I did a search. Thanks |
They look the same as the ones we have been discussing ... Safari Equip ones - x2 outrigger fittings each with 2 holes and one end hold for the chassis bolt.
You will need to remove your lower sills on both sided and then see how well the sliders line up One end fits onto the front end body bolt, with the other bits bolting onto the chassis outriggers - you will need to drill x2 holes into the end of the outriggers - take your time to mark the holes properly To fit - you will need x2 nuts and bolts per hanger (ie x4 nuts and bolts both sides) and some ‘spacer shims’ to fill the gaps which may be needed depending on the variable tolerance of landrover builds ... I am not a mechanic and managed to do this from start to finish in one day .. and did not need to trim my wheel arch lots of great info here to help you .. the best advice I can offer is to get your little wheel jack out to help - it made the job so much easier ! https://www.defender2.net/forum/topic78914.html ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Many thanks for the advice Wyvern!
Don’t suppose you have any idea what size any of the bolts etc are? I’m guessing I can just buy from a hardware shop. I might even finally be able to use my hi-lift for something! ![]() |
