Home > Maintenance & Modifications > suspension spring isolators |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 504 |
Learned ones
Thinking of fitting Disco spring isolators to ease the ride a little, question is I cant remember if it's D2 ones on the front and D1 ones on the back or the other way around. So if anybody's done it could you let me know. Thanks Wes Oh woe, oh woe My crusty old landrover, It will not go. |
9th Jul 2021 7:44am |
Fit D2 ones on the front, which incorporate the top spring clamp plate into the rubber:
Click image to enlarge If you have a 90, then fit D1 ones to the rear. If you have a 110 then the rear ones are more complicated as rear 110 springs are bigger than fronts and so normal Discovery isolators won't work. Instead, I used an Old Man Emu part that's intended for a Toyota (part no.OME80PR10), bought from Devon 4x4: Click image to enlarge If you're taking the springs out then take the opportunity to replace all of the hardware with galv versions. Details of what I used on my 110 are here: https://www.defender2.net/forum/post820610.html#820610 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Jul 2021 8:10am |
That's great, thanks for that. Did you notice much of an improvement?
9th Jul 2021 9:13am |
I think they take the edge off the harshness but they don't transform the ride, unfortunately. As they're so cheap, they're a worthwhile upgrade whilst doing other work - upgrading or renewing the springs and shocks, for instance - but I wouldn't go to the trouble of fitting them as a standalone task. Darren
9th Jul 2021 9:20am |
Great minds think alike mate, I'm doing the output shaft seal and thought I'd have a pop at these whilst I'm at it
Cheers Wes Oh woe, oh woe My crusty old landrover, It will not go. |
9th Jul 2021 9:46am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20512 |
I’ve got the castellated ones fitted top and bottom front and rear on my 90, never had a problem ever they’ve been on for at least 4 or 5 years now.
You can’t do that on a 110 on the rear as there are differences there. They don’t transform the ride but they do improve it, I much prefer it. It smooths out light shock loading such as small potholes at higher speed feels more of a little rumble than a bang into it. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
9th Jul 2021 8:11pm |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 |
Any thoughts or experience of the isolators on the rear by comparison with running lower rear tyre pressure. (Mine seems to be recommended 38psi rising with load- seems high.) Cheers, Guy.
10th Jul 2021 7:32pm |
That's achieving different things. The whole point of the isolators is to literally isolate the suspension from the chassis as an aid to reducing NVH. Running lower tyre pressures will get you a softer ride but doesn't stop the metal on metal interface between chassis and springs. Darren
10th Jul 2021 10:07pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Beat me to it Darren. Small cost and worthwhile - I did upper and lower at both ends. Rgds. Chris |
10th Jul 2021 10:46pm |
I run 32F and 34R tyre pressure.
I don’t tow anything over 750kg max, and this works well for me and have stuck with those pressures for a long while. This is on a 90 though. On a 110 or bigger or with any medium to heavy towing then higher rear pressure on the rear is probably a good idea. Generally speaking often or not you’ll find a lot of us do very similar things. I’ve never ran 38 on the rear, I find that far too hard, I did go for 36psi at one time but found 34on the rear to be perfect for me. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th Jul 2021 11:56pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Could I revive an older thread please?
There are a few threads on the use of isolators - another quite comprehensive one being here: https://www.defender2.net/forum/topic23909.html but that one doesn't really dwell on the discovery route - something that LandRoverAnorak has suggested in a few threads. I have a 2010 90 SW. I'm about to fit the following parts: 1) New genuine springs and dampers (take offs, 2015 SW spec) - bought 2) A full set of Superpro bushes - bought After advice from the forum, I'm also about to buy the following: 3) Gwyn Lewis HD, standard height galvanised front turrets (in my basket, awaiting payment) 4) 4x NRC9700 galvanised spring seats (in my basket, awaiting payment) 5) I'll also be getting new retainers for the rear. The use of some sort of isolator seems to be a bit of a no brainer: slight improvement at a low cost. I'd welcome the 10mm lift that comes with these, though 20mm (using isolators top and bottom) would be too much due to garage door height and concerns about driveline angle. Am I right in thinking that the best "OEM-plus" route for me would be to use: 1x pair of Discovery II front isolators, on the top of the front springs incorporating the retention rings 1x pair of Discovery I rear isolators on the top of the rear spring 1x pair of factory ANR3060 isolators on the bottom of the rear spring. ...or are the castelated isolators all round with standard front retaining rings a safer bet? Reliability is my main concern, with the benefits of the isolators running a close second. Does anyone happen to know if the disco II front and Disco I rear isolators provide the same amount of lift? (to keep the vehicle stance balanced). Just need to track down part numbers and then I'll get them ordered. Thank you. |
24th Aug 2021 1:22pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2254 |
I'd get the springs on first and see how it sits. Add isolators afterwards if you feel you need to lift a little. You may find the back a little lower than you expect.
The isolaters are not difficult to fit later but don't make any difference to noise or ride. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
24th Aug 2021 2:13pm |
There's no reason to doubt the reliability of the DII front isolators. They are basically an upgrade to the earlier D1 part and have the advantage of not requiring a separate securing ring. I had them fitted to my 110 last year, having done my 90 a few years earlier, but there must be thousands of DII's running around with them, fitted from new.
I've never seen the point in fitting isolators to the bottom of the springs as well as the top. The vehicle can't be more isolated than having just the top ones. I also think the levelling ability is somewhat overstated. By the time these things are fitted, the difference is closer to 7-8mm and you'd be hard pressed to be able to spot the difference Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Aug 2021 2:14pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Im not sure your isolator theory rings true from a physics standpoint but each to there own and any dampening is minimal anyway . I think most use both to regain a bit gf height..i was thinking of using the D2 isolators but I chose tha galvo GL ones instead.
24th Aug 2021 7:04pm |
